Why Do Some PCB Designers Use Soldered Fuses Instead of Fuse Holders?
  • Thread starter Thread starter Jobrag
    Pcb
Soldered fuses on PCBs are often preferred for safety reasons, as they prevent users from replacing blown fuses with larger ones, which can lead to dangerous situations. This design choice ensures that only knowledgeable individuals can replace the fuse, reducing the risk of fire hazards. Historical examples, such as early Ford vehicles, illustrate the effectiveness of built-in safety mechanisms over traditional fuses. Additionally, soldered fuses may simplify the assembly process for manufacturers. Ultimately, the use of soldered fuses reflects a commitment to safety and thoughtful design in electronics.
Jobrag
Any PCB designers, why oh why oh why do you inflict those (insert profanity) awful fuses that are soldered to the board, fuses in fuse holders make life so much easier.
I've been frustrated by those myself.
Only reason i can think of is this -
in some circles the fix for a blowing fuse is to put in a bigger one. Ever heard the phrase "Put a penny behind the fuse" ? That has burned down a lot of homes.
The soldered in fuse assures that it will be replaced only by somebody who has at least an inkling of what he is doing.
I like designed-in safety. Henry Ford was a genius at such things - headlight circuits in early Fords were protected by thermal overloads that cycled as they heated and cooled, so a faulted wire to a headlight would cause them to cycle on and off allowing you to limp home. A fuse would have left you with no lights at all. My '53 Ford was so wired and i think it dates back to 1929 Model A.
Some 1980's Fords have a headlight fuse inside the dimmer switch, which assures that should the headlight circuit develop a short it'll get fixed by somebody with at least the competence to find it, instead of putting in a bigger fuse and setting the car afire.
I don't know how it's done today.
So the answer to your question might be the proverbial 'ounce of prevention'
or it might be simply saving a step in assembly.
When studying designs it is often fruitful to ask yourself "Why would a rational man have done this?"
old jim
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
