Anything from Nothing: Uncovering the Possibilities
  • Context: High School
  • Thread starter Thread starter RajeshR
41 replies · 6K views
RajeshR
If something from nothing is true then "anything" can come from nothing .. What is stopping it ?
For all we know a totally different universe could have come from nothing or a Dragon or Sentient being could have come from nothing.
In short are there any theories to why only "this something" came from nothing. Why not anything else from nothing?
Astronomy news on Phys.org
Physics doesn't deal with "something from nothing". It deals with "something" (e.g. something is the present state of the universe) from "something else" (eg. the hot and dense state of the early universe). In other words, physical theories don't deal with creation of something per se.
bhobba said:
Where are you getting this idea physics says something comes from nothing?
He's probably been reading Lawrence Krauss's "A Universe From Nothing".
Since you never clarified, I will assume that you want a "pedestrian" answer to such a question, rather than the deep, mathematical description of the physics behind such a thing.
Coincidentally, a couple of days ago, an article by Ethan Siegel on a simple summary of the scientific meanings of "nothing" was published. I suggest you start your inquiry from there.
Zz.
anorlunda said:
Wow, thank you for the link Zz. It made a enjoyable read. It reminded me of Feynman's famous verbal essay on "why" questions.
You're welcome. Ethan Siegel has posted on Forbes many other easy-to-read articles for the general public.
Now, the question is whether the OP will actually come back and learn something from all the responses to the question, or is this another post-and-run thing.
Zz.
The universe could have been evolved much different way than ours. For example, we don't know why the nature constants have these particular values. If they were different the universe would be different.
We don't know and we can't know.
But you can try to look the situation, from the anthropic principle perspective.
I think nothingness is more of a philosophical idea. It's not something "physical" that we can measure, observe or understand.
bhobba said:
The modern theories I am aware of says the universe comes the false vacuum and inflation.
The inflation is where the universe "comes from"? Or it's just a era in the history of the universe?
I'll quote myself
The inflation didn't create the universe" but "it led to creating the universe as we currently know".
Inflation happened ##10^{-35}## second after the Big Bang singularity and we know that singularity doesn't belong to any point in space-time hence I think we can say that in the period between the BBS and cosmic inflation there was a false vacuum. At ##t=10^{-35}## cosmic inflation happened and then we know the rest.
(In here I considered slow roll inflation theory. There are of course other theories for inflation)
Cosmic inflation is just an era in the universe. We can think the universe before the inflation but after the Big Bang singularity.
This is not a good way of putting it, because "the Big Bang singularity" is not an actual event, it's an artifact of a particular model. Which, btw, is not even the inflationary model. Basically, what times like that mean, when they appear in a description of cosmological models, is: take the temperature of the universe at some particular event of interest (in this case, the end of inflation, when reheating is completed); take an idealized FRW model which does not include inflation, and figure out at what time after the initial singularity the universe had that temperature; then give that time as the "time" of the event of interest.
Personally, I would rather that cosmologists just gave temperatures directly, instead of trying to convert them to times using a model that isn't even the right one. But that is the common custom.
What's this means?
I see your point since the reheating happens the temperature of the universe would be the approximately same after and before the inflation.
But don't you think we need time or time interval to understand where the inflation started and ended? Since as you said If I just say it happened at ##10^{27}## K there will be confusion about, Is it the end of inflation ? or the beginning of the inflation?
Arman777 said:
What's this means?
Just what I said, and described in my previous post. The model from which times like ##10^{-35}## second come from is not the actual inflationary model cosmologists are using. It's an idealized non-inflating FRW model. The correspondence between the two models, that is used to get the times cosmologists give, is done using temperature.
The actual inflationary model cosmologists are using doesn't even have an "initial singularity" in it at all. We don't know whether there was such a thing or not; in some inflationary models (the "eternal inflation" ones), the universe has no beginning, it extends infinitely far backward in time. Currently we don't have any way of testing which models are correct, so our current best-fit model makes no commitment on whether there was an initial singularity or not; it simply goes no further back than the beginning of inflation.
I think you mean after and before the reheating? That is not the case: before reheating, there was a huge potential energy stored in the inflaton field, which had zero temperature (it was in a "false vacuum" state). After reheating, all of that energy is now in the Standard Model fields, which are therefore at very high temperature (because there is no "false vacuum" state for them, whatever energy they have is kinetic energy and must show up as temperature, at least under the conditions right after reheating, when all of the SM fields are massless).
If we do, then cosmologists aren't telling us what the actual time or time interval was. See above.
Arman777 said:
If I just say it happened at ##10^{27} K## there will be confusion about, Is it the end of inflation ? or the beginning of the inflation?
The way to fix that is easy: just say which.
You can't even define nothing, so something from nothing is meaningless. Not false, meaningless. Despite this some top physicists still use the term in popular literature. It sells books.
Does all this really mean that there really never was "nothing". Is the Cosmos a never beginning and never ending existence? Is there any proof to this? Or is everything on this topic speculation?
Arman777 said:
What's this means?
We don't even know whether "before the inflation" existed. I, for one, like eternal inflation models, where most of the Universe is in false vacuum state and inflating all the time, and was inflating in the past for unknown, possibly infinitely long time. True vacuum patches (like ours, containing observable Universe) are actually an exception, a very small fraction of the volume.
Yes, I am aware of that.
PeterDonis also said it.
I think it's just metaphysics.
Can we define nothing as an empty set where S={ } ?
phinds said:
That's math, not physics.
Indeed but mathematically we can define.
"Whatever is is and cannot no be". "Matter cannot be created nor destroyed".
But, was it always thus? If entropy will be the end of our universe, will energy always be present?
Can a dimension disappear, while others thrive? I think that metaphysics studies what is, but not what was or will be.
Sure, but how do you match up the math to experiments? Suppose we say that the state of the universe is the empty set. What experimental predictions does that translate to?
Can physics define what was or will be? I think outcomes can known from physics as well as understanding events in the past. But there seems to be a limit to what physics can conclude with certainty. Mathematics has the same restriction. Until verified conclusively as a reality that is observable, neither can present what did happen as well as what will happen if it passes the limits of the possibility of that which is observable. For instance,
the computer chip in cars that regulates data that it is given, as well as sending messages to what it controls, has to be tested and proven reliable after being programed and connected to controls in the car.
Well I can't match up with the experiment...
Also I said earlier that,
But I find that "The empty set is not the same thing as nothing; rather, it is a set with nothing inside it and a set is always something." which makes sense.
https://en.wikipedia.org/wiki/Set_(mathematics) (its a wiki qoute but the idea makes sense)
You are right.
cave man said:
... there seems to be a limit to what physics can conclude with certainty. Mathematics has the same restriction.
No, mathematics has no such restriction. As long as it is internally consistent, math is certain.
Then it's off topic here. You can discuss set theory in the math forum.
Am I correct in understanding that subatomic particles come in and out of existence randomly? In that case, is something coming from nothing?
