Which Salts Form Basic Solutions in Water?
A buffered solution is defined as one that resists changes in pH, typically containing a weak acid and its salt, and can react with both H+ and OH- ions. For the second problem, salts that form basic solutions in water include those that yield hydroxide ions upon hydrolysis. The discussion highlights that Na2CO3 is likely to create a basic solution due to its strong base component, while salts like NH4NO3 will not. Understanding the reactions of these salts with water and the concept of hydrolysis is crucial for determining their basicity. Overall, the conversation emphasizes the importance of recognizing the components of salts and their behavior in aqueous solutions.
wonka08
OK so this is my first time actually posting but I have lurked around. I need help with two of my chemistry problems.
Problem 1
Decide which one(s) of these answer choices are correct.
A buffered solution is one which can be desribed by which of the following:
I. a solution which resists pH
II. may contain a weak acid and its salt
III. contains species which can react with both H+ and OH-
Problem 2
Which of the following salts will form a basic solution in water?
a. KCl
b. Na2SO4
c. CuCl2
d. Na2CO3
e. NH4NO3
No equations for question 1.
Question 2 wouldn't the products have to have the OH ion or will water autoionize?
For problem 1 I already know that answer choices "I and II" are correct. My question is about the third. I don't understand what the statement is saying and whether it is true or not.
For question 2 I thought that what reacts with water will have to have an OH- to become a basic salt.
Thanks to those who can help
a buffered solution is a solutions which resists change in pH. So what you have initially say is a weak acid and a weak base. Let's say you add a strong acid like HCl, which has a low pH, and will generally make your solution more acidic. Once you do this, your weak base will react with the strong acid, creating a weak acid and possibly water. So now that strong acid will in a way be converted to a weak acid, only slightly decreasing the pH. For the second one, you basically want to split up the two components of each molecule. It seems that a bunch of them have strong acid components, and a bunch of them have strong base components. You might have to do some log[OH] and log[H] calculuations. So basicaly we know NaOH is a strong base, so chances are that one will create a strong base. we Know HNO3 is a strong acid, so that one will not be basic. and so on.
Imagine solution of acetic buffer. It contains both CH3COO- and CH3COOH. What happens when you add base? What happens when you add acid?
Do you know what is Broensted definition of a base? Do you know how ammonia reacts with water and why its solutions are basic? Can you write reaction equation? Or perhaps you have neard about hydrolysis?
methods
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
