Apollo 1 command Module Pressure/Force
  • Thread starter Thread starter mr.toronto
    Apollo module
The discussion centers on calculating the force on the Apollo 1 command module hatch during the "plugs out test," with external pressures of 14.8 PSI and 17.5 PSI noted. The conversion of these pressures into Pascals reveals values of approximately 102,042.15 Pascals and 120,657.95 Pascals, respectively. To determine the force, the area of the hatch is necessary, with a rough estimate of 0.25 m² suggested. The key formula to use is Pressure = Force / Area, which requires calculating the pressure difference between the inside and outside of the module. Understanding these principles is crucial for accurately assessing the forces acting on the hatch.
mr.toronto
What would have been the force on the hatch of the Apollo 1 command module (Before the fire) during the "plugs out test"
more info 14.8 PSI of pressure outside of the module and 17.5 PSI
1 PSI= 6 894.75729 pascals. 14.8 x 6894.74=102 042.152 Pascals
17.5 x 6894.74=120657.95 Pascals
so I'm kind of stuck here.
You need to know the area of the hatch. I had a quick look round but couldn't find it anywhere.
If you wanted to make a rough guess you could assume perhaps 0.25 m^2 and go from there. You need to use the formula:
Pressure = Force * Area
so what would I do for the pressure though
You just need to caclculate the pressure difference between the inside and the outside.
It's just like if you wanted to calculate the next force acting on a body if it had 4N acting on it one way, and 10N acting on it the opposite way. The net force is 6N, in the direction of the biggest force.
This is just the same, but instead of forces you're dealing with pressures, which are the force over a unit area.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
