Application of integration: Volume
6 replies · 8K views
nyyfan0729
Find the volume of the right cone of height 9 whose base is an ellipse. Major axis 12 and minor axis 6.
use the formula for the volume of a cone.
I didn't know there was a formula for the volume of a cone with a non-circular base!
Hmm- I guess there will be once we do the integral!
nyfan0729: At height "y" above the base of the cone, a cross section will be an ellipse with major axis of length (2/3)(9- y) and minor axis of length (1/3)(9-y): that would have area
[tex]\frac{2\pi}{9}(9-y)^2[/tex]
It should be easy to integrate that from y= 0 to 9.
If it is done correctly, it is one third of the product of the base area and the height (a right cone is, of course, assumed):
Let (x,y) be an arbitrary point in the base area A lying in the plane z=0, and for simplicity, let the position of the apex be (0,0,h), where h is the height,
Thus, the cone may be represented as:
[tex]\vec{F}(x,y,t)=((x,y,0)-(0,0,h))t+(0,0,h)=(xt,yt,h(1-t)), (x,y)\in{A}, 0\leq{t}\leq{1}[/tex]
The Jacobian is [itex]ht^{2}[/tex], from which the volume formula follows:<br /> [tex]V=\int{dV}=\iint_{A}\int_{0}^{1}t^{2}hdtdA=\frac{h}{3}\iint_{A}dA=\frac{Ah}{3}[/tex][/itex]
Arildno,
I believe the result is even more general than that. You don't have to assume a "right cone." As long as the horizontal cross sections of the cone are self-similar then you'll get the same result.
Tide said:
Arildno,
I assumed a "right cone" since that was assumed in the exercise.
You are right, of course..:wink:
But it's obviously half the volume of a right circular cone of diameter 12 because it's just compressed to half size in the direction of the minor axis, so [tex]\frac{\pi 6^2}{2.3}[/tex]
