Applications of hypothetical new material
The discussion centers around a hypothetical metal with high electrical conductivity and corrosion resistance but low thermal conductivity. Participants explore its potential industrial applications, particularly in electronics and power transmission, where managing heat is crucial. While high thermal conductivity is typically desirable for efficient heat dissipation, the unique properties of this imagined metal could offer advantages in specific scenarios, such as electric connections in extreme temperatures, like those found in superconductors. The corrosion resistance suggests potential uses in nuclear reactors and rocket engines, especially for components that require durability under harsh conditions. However, the relationship between thermal and electrical conductivity complicates its practical applications, as some level of thermal conductivity may still be necessary for effective operation in many industries.
cbrons
Lay person here...
If there was a new metal that was discovered with extremely high electrical conductivity and corrosion resistance but no thermal conductivity, what do you image its industrial uses might be?
"No thermal conductivity" is of course not physically realizable, especially a metal, but one could imagine materials with relatively low thermal conductivity.
Yes sir, it's just a thought experiment.
I was thinking this would have applications in electronics? Does thermal conductivity correlate inversely with how good an element is in certain industrial applications?
Power transmission seems the most obvious application.
Structural insulation; HVAC systems; domestic and commercial refrigerators... really, the uses are endless.
The corrosion resistance aspect would seem to indicate extensive potential in nuclear reactors and rocket engines.
Likes cbrons
Unfortunately, electronic and heat conductance are linked quite closely.
Anyway: For electronics and power transmission, you usually want to get rid of heat, so thermal conductivity is good and the material here would be bad. Such a material would make electric connections to very hot and/or very cold places (like superconductors) easier.
Likes cbrons
Could you see any use in nuclear reactors and rocket engines?
If we also have electronics that can resist high temperatures (and ideally also radiation in case of nuclear reactors), maybe for some monitoring electronics? But then some thermal conductivity wouldn't be so problematic I think.
I was thinking along the line of piping between the core and the heat exchanger system.
