What is the Arc Length of y=\sqrt{x} from x=0 to x=2?
The arc length of the curve defined by y = √x from x = 0 to x = 2 can be calculated using the integral s = ∫_0^2 √(1 + 1/(4x)) dx. The correct answer is derived as s = ½(3√2 + ln(1 + √2)), approximately equal to 2.56. Various methods were attempted, including trigonometric substitutions and changing the function to y = x², which simplifies the problem due to symmetry. The discussion highlights the importance of correctly setting limits and choosing appropriate substitutions in integral calculus.
  • Understanding of integral calculus
  • Familiarity with trigonometric substitutions
  • Knowledge of arc length formulas
  • Experience with logarithmic functions
  • Study the arc length formula for parametric curves
  • Learn about trigonometric substitutions in integrals
  • Explore the properties of inverse functions and their symmetry
  • Practice evaluating integrals involving logarithmic and square root functions
Students studying calculus, particularly those focusing on integral calculus and arc length calculations, as well as educators seeking to enhance their teaching methods in these topics.
bigevil
Find the arc length of y=\sqrt{x} from x=0 to x=2.
I don't know, this is a nastier integral than it looks. From the substitutions,
s = \int_0^2 \sqrt{1 + \frac{1}{4x}} dx. From doing this over and over again I already know the answer will have square roots and logarithms but I keep getting it wrong!
I've tried two methods so far, both end with evaluating \int cosec^3 x dx, but with different limits.
Heres one: u = \sqrt{1 + \frac{1}{4x}}. Then, I get s = \int_1^{\sqrt{9/8}} \frac{u^2}{- 2(u^2-1)^2} du
Substitute u = sec \theta, s = \int_{0}^{sec^{-1} \sqrt{(9/8)}} - cosec^3 \theta d\theta = \frac{1}{8}(3\sqrt{2}... which has the wrong form.
(2 \int cosec^3 x dx = - cot\theta cosec\theta - ln|cot\theta + cosec\theta| + c by integration by parts.)
The answer is \frac{1}{2} (3\sqrt{2} + ln (1 + \sqrt{2}) or about 2.56. I'm quite sure my general method is correct (the square roots and logarithms are consistent with the ansewr), but there's a problem with the limits.
The other one is to substitute a trig expression directly (ie \frac{1}{4x} = tan^2 \theta, with different limits.
Here's something different you might try. Instead of working with y = sqrt(x), you could instead work with y = x^2. The arc length along your curve between x = 0 and x = 2 is exactly the same as the arc length along the curve between x = 0 and x = sqrt(2). If you draw the graphs of y = sqrt(x) and y = x^2, you should be able to convince yourself of what I'm saying.
The integral becomes:
\int_0^{\sqrt{2}} \sqrt{1 + 4x^2} dx
You can use a trig substitution here, with tan \theta = 2x.
Mark, thanks so much, that worked. You meant that since x^2 is the inverse function, it is exactly symmetrical about the y=x, so (2, root-2) maps to (root-2, 2), right?
But I hope to be able to solve the original problem as-is. Just changing functions unfortunately won't reveal what was wrong with what I did above.
  • · Replies 105 ·
  • · Replies 22 ·
