Archimedes Screw: Power Generation in Pulsating Environment?
  • Thread starter Thread starter dffhkhksg
    Archimedes Screw
An Archimedes screw generator may struggle to operate efficiently in a pulsating environment due to its reliance on a constant flow of water to generate electricity. The mechanism works best when the water continuously drives the screw sideways, which may not occur in a zero-head scenario similar to blood flow. Fluid friction could potentially cause the screw to rotate in the opposite direction after a few turns. Additionally, the power generated by the screw is influenced by factors such as its size, surface area, inclination, pressure, and fluid speed. Overall, the effectiveness of this technology in non-constant flow conditions appears limited.
dffhkhksg
Hello,
I am wondering whether an Archimedes screw generator would work in a pulsating environment. What I mean by this is does the screw require constant flow in order to generate electrcity? Or could I put such a screw in a pressure driven yet zero-head environment(similar to blood flow)?
Also, what is the equation for the amount of power such a screw would generate in relation to it's size, surface area, inclination, pressure and speed of the fluid passing through it?
Thank You.
dffhkhksg said:
Hello,
Thank You.
I think it would be very inefficient, as the screw works by a vector component of the weight of the water driving continuously sideways as the water makes its way down. In a simple flow situation, after a few turns it is the water that will be moving sideways (spirally), and due to fluid friction, might even turn the screw the 'wrong' way. That's the way I see it in my mind visually, anyway.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
