Are neutrinos much more abundant than atoms?
Stephanus
Dear PF Forum,
I once read in several links just a couple of days ago, that the number of neutrinos exceeds the number of baryon in the universe by several orders of magnitude.
1. Is that true, that neutrinos are much more abundant than atoms?
2. Do neutrinos have mass? Not that they are catholic :smile:
3. If they have mass, I know I should have calculated it myself, which is more massive? Neutrinos or atoms in the universe?
4. Baryon asymetriy.
Does that includes electron and neutrino?
Thanks for any explanation.
Yes, at least according to the standard picture we have of the Universe. It should be said that most neutrinos are very low energy background neutrinos and this background has yet to be experimentally verified. If true, and again this is a must based on standard cosmology, the only particle more abundant would be photons due to the CMB.
Yes. The observation of neutrino oscillations verifies this.
Baryons are far heavier than neutrinos. Based on your question, you are looking for which has the higher mass density, the baryons still win - a proton is at least 1000000000 times more massive than a neutrino.
No. Neutrinos and electrons are not baryons.
Likes Stephanus
Thanks Orodruin for your answer :smile:
About baryon asymmetry. Okay... electrons and neutrinos are not baryon, they're lepton.
But according to CERN,
http://press.web.cern.ch/backgrounders/matterantimatter-asymmetry
... about one particle per billion – managed to survive...
As you may already know, this happens in baryogenesis, less than 1 second after big bang.
But if the number of electrons doesn't not match or closely match to the number of protons, should the universe contains highly ionized atoms?
Thanks for your response.
That there is a baryon asymmetry does not imply that there is no lepton asymmetry. In fact, in order for the Universe to be overall neutral there needs to be roughly as many electrons as protons. This does not mean that the lepton and baryon numbers are equal, a lot of the asymmetry may "hide" in neutrinos. The cosmic neutrino background contains both neutrinos and anti-neutrinos (assuming that they are different particles).
Likes Adit and Stephanus
Thanks again Orodruin for your answer :smile:
May I ask further?
It turns out that there are leptogenesis as well :smile:
http://en.wikipedia.org/wiki/Leptogenesis_(physics)
But WHY does leptogenesis asymmetry closely matches baryon asymmetry?
1. Is leptogenesis and baryogenesis asymmetry match - still -one of the science mystery?
2. Is leptogenesis science mystery?
3. Is baryogenesis science mystery?
Thanks for any response.
The Standard Model of particle physics allows for a non-perturbative effect called "sphalerons". During sphaleron processes, lepton and baryon numbers are not preserved but are exchanged (B-L is preserved while B+L changes). This leads to baryon number being converted into lepton number and vice versa as long as the sphaleron processes are active (as long as the Universe is hot enough) and the ratio will be fixed as long as they are fast enough to ensure that the process is in equilibrium.
We do know of several mechanisms through which baryogenesis via leptogenesis (producing the lepton asymmetry first and then having it "spill over" to baryons through sphalerons) could work. The big problem here is that leptogenesis requires the existence of some heavy leptons which have not been observed yet, meaning that it still remains a possible solution only and not a tested hypothesis. Currently, we are not sure how baryogenesis happened, there are some different alternatives, but nothing is confirmed.
Likes Stephanus
Thanks Orodruin for you explanations.
Orodruin said:
... lepton and baryon numbers are not preserved but are exchanged (B-L is preserved while B+L changes). This leads to baryon number being converted into lepton number and vice versa...
Perhaps my English is poor (and also my math), but..
If lepton and baryon numbers are exchanged, shouldn't it B + L = C, constant?
On the other hand, if B - C = C, constant, should we say that , the difference between Baryon and lepton numbers are constant, although B/C might changes. Or the equation is wrong?
Thanks for your answer.
You exchange a lepton for an antibaryon or vice versa. The difference is constant, right.
There are models where B-L is not exactly conserved, but that is a different thing.
If you have no baryon so B=0 and a lepton with L=1 and you say there is a B-L symmetry...
Then B-L=-1 , so if conserved you can have as a result an antibaryon where B=-1 and no lepton L=0 (a lepton has changed into a antibaryon)...
The B+L = 1 at first, then B+L =-1
On the other hand, if B - L = C (not B - C = C, edited), constant, should we say that , the difference between Baryon and lepton numbers are constant, although B/L (not B/C, edited) might changes. Or the equation is wrong?
Bold red is EDITED!
Thanks ChrisVer for your answer,
But it's Orodruin phrase that I like confirmation:
Perhaps my understanding in English (or Math) is incorrect.
IF ...lepton and baryon numbers are not preserved but are exchanged, shouldn't it B + L = constant?
It's not the physics that I like to know, but the phrase. So I can get the correct answer.
Did you read my answer in post 8?
The "exchanged" in Orodruin's post didn't specify the sign.
Likes Stephanus
This.
I considered the sign evident from the conservation of B-L.
Likes Stephanus
Oh, it's the "subatomic number", I think it's the "amount" of baryon.
Okay, I think this is really particle physics. Sorry, I really have no background in this area.
But, thanks for the answer.
