Are Photons Timeless? | Federico
  • Thread starter Anymodal
  • Tags
    Photons
In summary: Time dilation, energy increase (formerly loosely called 'mass' increase), and longitudinal length contraction, with respect to the frame of reference of a body with a different velocity, in Special Relativity.
Anymodal
I'm not a physicist, I'm only taking my first subject on physics in Eng. here in Buenos aires, so I don't know much about it. But i find it so interesting that I spend some deep hours of thought ofently in it, and i just want to clarify this concern:
According to relativity your local time respect with someone else's time will dilate in function of the gravity field and your speed respect to him (Is that right?). As you move faster time will flow slower (just a way of putting it because time doesn't flow, does it?). When you get close to the speed of light time will dilate asymptotically to infinite. So if you would move at te speed of light -wich is impossible because it would take an infinite amount of energy- your time relatively to the to the other observer will dilate infinetely.
Photons travel at light speed. Therefore time doesn't flow for them. Does that mean that photons are timeless? Their existence is intrinsic to the time sacle of the Universe? Does a photon exist in itself without reggarding the events of the Universe? (I think i know they don't because if you can experiment with photons you are interacting with them of course, but i say it so you would point out what is the logic gap in this thought, if there is). What is it's nature of existence? What can you tell -anything- about a photon reggarding this aspect? Or - of course- What is wrong with my logic?
Thank you!
PS: Photons are massless aren't they? But they are quantums of energy which is equivalent to some mass, so it still makes sense thinking about photons as something that can be subjected to the time dilation, doesn't it?Anymodal-
Federico.
Hit up the faq here and read about a frame of reference for a photon.
You're essentially correct. Photons do not experience time. It can have no frame of reference
They are massless and have energy, but that does not make it equivalent to having mass. They do have momentum, however.
Photons do not experience time and that's just how they work. One thing you have to deal with is that not everything needs to experience every type of parameter you can imagine. For example, in thermodynamics you say that a large number of particles can have a temperature. The deal with thermodynamics and statistical mechanics, however, is the assumption of a large number of particles. If I were to isolate a single particle and ask "what is the temperature of this particle", the question would not make sense as a temperature is only applicable to a certain type of system. For the idea of relativity, time is a concept only applicable to massive systems.
Hi, Federico,
What you said in the main body of your post makes sense to me. The PS didn't make sense to me -- I don't see how mass is relevant.
-Ben
bcrowell said:
Hi, Federico,
-Ben
I think he is saying the energy of a photon is the same thing as mass, and since mass-carrying entities are subject to the other phenomena of shifted reference frames, time-dilation should be included.
This misinterprets the mass-energy relationship, which not 'equivalence' in the complete formal sense. e=mc2 shows an 'exchange' relationship, as it were, but dollars are not the same thing as groceries.
Thanks! you figuered what i meant (and expanded it and corrected it :P). What are phenomena of shifted reference frame other than time dilation?...
Thanks every body for answering! i will reply you later
I'll let someone give you a more complete answer. My area is linguistics, not physics.
Anymodal-
Federico.
I would disagree that photons are timeless in their experience. Photons have energy. And the Conservation of Energy has never been found to be violated in the universe. So photon energy is timeless in the sense that its energy is always conserved.
However because Photons can be "Redshifted;" this means that as Photons travel through space they can experience an increase in their wavelength, a decrease in their frequency, and an increase in the time component associated with the frequency of the photon.
See Wiki: http://en.wikipedia.org/wiki/Redshift"
Best
Best
None of the above means that the photon experiences time.
Best
This is conflating the various uses of the terms 'timeless' and 'time'. One need only say that a fundamental property of light is frequency cycles/t. In that case we don't need red-shifting at all.
I don't think this argument quite works. First let's simplify it a little. The idea of using redshifts brings up all kinds of connotations of general relativity, but it's not necessary to get that fancy. It's clear on much more fundamental grounds that the properties of a photon can change over time, where time is measured in the frame of reference defined by some material observer. A photon that bounces perpendicularly off of a mirror flips its momentum vector, so its properties change over time, where time is measured in the frame of the mirror. If a particle couldn't change its properties over time at all, then that would be a completely noninteracting particle, and therefore we wouldn't be able to observe it.
The problem with your argument is that it only shows the existence of some frame in which the photon changes its properties, but that isn't really the issue being discussed. The issue is whether there is a frame moving with the photon such that the photon's properties change over time. There isn't.
Best
DaveC426913 has it right. Although the photon exists in spacetime, it cannot experience the passage of time as material entities do. If it cannot be held in a state of rest, it cannot experience time.
GrayGhost
What is time?
atyy said:
What is time?
It's a 4 letter word! Don't make me get the soap and wash your mouth out!
atyy said:
What is time?
Start yer own thread.
:wink:
When you do a Lorentz transform to a reference frame traveling at the speed of light, all time intervals and lengths become infinite.
So this means looking at the universe from the photon's point of view doesn't tell us anything useful.
If you think about it, from the photon's point of view, it would have no mass and no momentum, so it would cease to exist, so it makes no sense to look at the world through the photon's eyes. (Someone correct me if I'm wrong, but I think this is basically the right idea).
Sorry, I got a bit of that wrong.
All lengths in the same direction as the photon would go to zero because of length contraction.
atyy said:
What is time?
It's what prevents me from giving a complete answer to that question right now :-)
atyy said:
What is time?
Baby don't hurt me...
:smile:
Fermat thought that was space, but he lived before Lorentz covariance.
"no more" = "no time"?
1. Are photons truly timeless?
The concept of timelessness in photons is a complex one. According to the theory of relativity, time is relative and can appear to pass at different rates depending on one's frame of reference. Photons, being massless particles, do not experience time as we understand it. However, this does not necessarily mean they are completely timeless.
2. How can photons have no mass and still exist?
Photons are particles of light that do not have mass in the traditional sense. Instead, they have energy and momentum, which are related to mass through Einstein's famous equation, E=mc². This means that photons do have some properties typically associated with mass, but they are fundamentally different from particles with mass.
3. Can photons travel at the speed of light?
Yes, photons travel at the speed of light, which is approximately 299,792,458 meters per second in a vacuum. This is the maximum speed allowed in the universe, according to the theory of relativity. Photons do not experience time, so they do not have a concept of "traveling" at a certain speed. Instead, they simply exist and interact with their surroundings at the speed of light.
4. Do photons have a lifespan?
Since photons do not experience time, they do not have a lifespan in the traditional sense. However, they can be absorbed or scattered by particles they interact with, which effectively ends their existence as photons. In this sense, they can be said to have a "lifetime," but it is not the same as the lifespan of living organisms.
5. What is the relationship between photons and time dilation?
Time dilation is the phenomenon in which time appears to pass at a different rate for observers in different frames of reference. This is a fundamental concept in the theory of relativity. Photons, as massless particles, do not experience time and therefore do not undergo time dilation. However, their interactions with particles that do experience time can be affected by time dilation. This is why the speed of light is constant for all observers, regardless of their frame of reference.
