Are the Reasons for Pendulum's Mass and Amplitude Independence Contradictory?
The discussion centers on the independence of a pendulum's time period from its mass and amplitude, exploring the reasons behind this independence and whether they are contradictory. Participants delve into the concepts of gravitational acceleration, restoring force, and the mathematical underpinnings of pendulum motion, with a focus on both theoretical and mathematical aspects.
  • Some participants assert that the time period of a pendulum is independent of its mass and amplitude, citing gravitational acceleration as constant regardless of mass.
  • Others argue that while gravitational acceleration is constant, the restoring force increases with amplitude, suggesting a complexity in understanding how these factors interact.
  • A participant highlights that simple harmonic motion requires the restoring force to be proportional to displacement, which may not hold for all pendulum scenarios.
  • Concerns are raised about the avoidance of mathematical explanations, with calls for using differential equations to clarify the motion of the pendulum.
  • Some participants emphasize that the acceleration of the pendulum bob is not constant but varies with displacement, challenging the notion of uniform acceleration.
  • There is a discussion about the tangential force acting on the pendulum and how it relates to gravitational force as amplitude increases.
Participants express differing views on the relationship between mass, amplitude, and the time period of a pendulum. While some agree on the independence of these factors, others highlight contradictions and complexities, indicating that the discussion remains unresolved.
Participants note that the mathematical treatment of pendulum motion is essential for a complete understanding, and there are unresolved aspects regarding the assumptions made about restoring forces and the conditions under which simple harmonic motion applies.
This discussion may be of interest to those studying physics, particularly in the areas of mechanics and oscillatory motion, as well as individuals looking to deepen their understanding of pendulum dynamics and the mathematical frameworks that describe them.
Kaneki123
Okay...The time period of a pendulum is independent of its mass and amplitude.For the "independence of mass",the reason is that, for same amplitude (distance from mean position), any change in mass would have no effect on the acceleration of the mass (gravitational acceleration is constant);hence the mass will reach the mean position at same time...But for the "independence of amplitude'', the reason I found is that, for a same mass, increase in amplitude would result in increase in restoring force, which would result in increase in acceleration; increased distance would increase acceleration and hence the mass will reach the mean position at the same time...Now my question is that, are'nt these two reasons contradictory, like one says that acceleration remains constant and the other states that the acceleration would increase?Any help will be appreciated...
Okay...Any freely falling body on Earth will have acceleration of 9.8 ms-2.Suppose that in case of a pendulum, the bob is taken to the right of its mean position...Now only a ''component of weight'' will be acting as a net force on the bob...My question is that, will the acceleration of the bob in this case also be 9.8ms-2 (same as gravitational acceleration), or will it be different?
Well, it isn't exactly true for a pendulum. Simple Harmonic Motion is only followed when the restoring force is exactly proportional to displacement - as with a steel clock spring.
But there is no way to discuss the details of the motion without using Maths and solving the differential equation of motion. That's the only real explanation and arm waving cannot suffice, I'm afraid.
The acceleration towards the rest position is not constant but is proportional to the displacement. You have more or less described what goes on but what you can't 'prove' that way is how that effect produces equal time periods of cycles of all amplitudes. That has to use the Calculus.
With the bob at the same level as the pivot, the downwards acceleration will be g. Not for other angles, though. At other angles, the force towards the pivot becomes relevant and the motion is due to mg and the tension. This link says it all, with pictures.
I think you may have Mod trouble for posting about the same topic on two threads. You will probably be 'merged'!
Two threads have been merged as the issue could possibly be solved for both. This is an exception, because both questions are closely related.
Can you give me a valid reason as to why the time period does not (or a little) depend upon the mass of the bob?
That aspect I feel is a bit more obvious. I mean, disregarding friction, all objects accelerate at the same rate towards earth, independent of mass. So, imagine the pendulum is at a horizontal 90 degree position (extreme case, but just for illustration). If you split the weight into two parts that are now hung off two separate connections, the weights will fall at the same rate as the big combined weight.
Can you give me a "valid reason" why you didn't read the link I gave you? It has all you need to know about a simple pendulum, including how the mass disappears from the derived equation. We do expect people to try, just a little and not be spoon fed with everything.
Is there some reason why math is being avoided here? It seem like a lot of this could be address quite simply with the relevant diagram and associated differential equation of motion.
See the link in post #4 of this thread.
the reason you gave brings me to my original question that, mass is excluded because gravitational acceleration is constant(regardless of distance from mean position), but in case of amplitude, the amplitude is excluded because acceleration is directly proportional to distance from mean position?
That is the defining property of a harmonic oscillator: The restoring force and hence the acceleration is directly proportional to the displacement. That condition leads to a differential equation in which the amplitude drops out.
Ir is worth noting that a pendulum is not a perfect harmonic oscillator, but as long as the angle of swing is small enough that ##\sin\theta\approx\theta## and the mass is concentrated in a point at the end of the string it's pretty close.
Several hundred years ago it was acknowledged that most aspects of Science - particularly Physics - are described best using mathematics. It is, as far as I can see, futile to try to produce alternative, hand waving explanations when the explanation is perfectly clear to anyone who is prepared to do the Maths. People who are not prepared to involve the Maths must really just accept simpler explanations because they are not in a position to argue against them.
The Maths in the link I posted way back, answers all your questions.
The force of gravity acts down while the force which accelerates the pendulum is tangential to its circular motion. When the amplitude of the pendulum increases, the direction of these two forces gets more similar which means that a larger component of the force of gravity is rotating the pendulum. This force is Fgsinθ with θ being the amplitude. This is clearly shown in a image from the link.
Note that the force of gravity itself remains constant.
  • · Replies 36 ·
