A Time Dilation in Gravitational Fields: Are Equivalent Formulas?
  • A
  • Thread starter Thread starter Emmacastellano80
    Equivalent Formulas
Emmacastellano80
TL;DR Summary
I was trying to understand the topic of time dilation in a gravitational field, and I found these two formulas:
http://it.tinypic.com/r/1124ha0/9
http://it.tinypic.com/r/1z22l53/9
G = constant grav.
m = mass of the planet or star under consideration
g = 9.81m / s ^ 2
H = height at which the second clock is located with respect to the first which is on the ground.
My question is :
are these two formulas equivalent?
G = constant grav.
g = 9.81m / s ^ 2
My question is :
No. They apply in completely different circumstances. One gives the symmetric time dilation effect between observers in relative motion in flat spacetime, the other the asymmetric time dilation between hovering observers in curved spacetime.
Edit: to save people clicking on the image with annoying ads, the two equations are the Lorentz gamma factor, ##1/\sqrt{1-v^2/c^2}##, and the gravitational time dilation factor between an observer at rest at infinity and another hovering at ##r## in Schwarzschild spacetime, ##1/\sqrt{1-2GM/c^2r}##.
Oh, and the third formula is the time dilation effect in a uniformly accelerated rocket. So it's possible I'm misinterpreting which two formulae are being talked about.
Which two formulae are you asking about? It would be easier if you used LaTeX to type out the maths. There are instructions in a link just below the reply box.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
