Area of a Hexagon: Find the Area with Radius r
  • Thread starter Thread starter Rossinole
    Area Hexagon
The area of a hexagon inscribed in a circle of radius r can be calculated by dividing the hexagon into six equilateral triangles. Each triangle has a height that can be expressed in terms of the radius r, leading to the formula for the area of the hexagon being (3/2)r²√3. The discussion clarifies that the term "impressed" should be replaced with "inscribed" to accurately describe the relationship between the circle and the hexagon. This problem is fundamentally a geometry exercise rather than a calculus one.
  • Understanding of basic geometry concepts, particularly the properties of triangles.
  • Familiarity with the Pythagorean theorem.
  • Knowledge of the formula for the area of a triangle.
  • Ability to manipulate algebraic expressions involving square roots.
  • Study the derivation of the area formula for regular polygons.
  • Learn how to express geometric properties in terms of inscribed circles.
  • Explore the relationship between the radius of a circle and the side lengths of inscribed polygons.
  • Investigate advanced geometric concepts such as the use of trigonometric functions in area calculations.
Students studying geometry, particularly those tackling problems involving inscribed shapes, as well as educators looking for clear explanations of geometric principles.
Rossinole
A circle of radius r is impressed in a hexagon. Find the area of the hexagon.
Area of a triangle = (1/2)bh
The hexagon can be split up into six triangles, and with the formula for the area of a triangle, becomes (6)(1/2*bh).
Does the circle in the problem even matter? It makes it seem like there is more to the problem than there really is. Is there something I overlooked?
what do you mean with : a circle of radius r is impressed in a hexagon? I think you have to use the radius of the circle on your answer. But if you could explain this part a lill bit more, what do you mean by that.
Do you mean "inscribed" instead of "impressed"? This question (post #1) is not really a Calculus problem; did you intend it to be for Calculus? Without using Calculus, this is a very simple exercise needing only intuitive knowledge of pattern in a shape and the pythagorean theorem.
It's just the sum of the areas of six identical triangles, each with two legs of length r and a central angle of 360 / 6 = 60 degrees. It's basic plane geometry.
- Warren
well, i think what they are asking you to do is express the area of the hexagon in terms of the radius of the circle. Your formula is right, just try to express the height of the triangles in terms of the radius, and use the letter r. Also notice that all three sides of the triangles are of size r.
It's meant to be a Calculus problem, or at least it's on my Calculus homework.
Alright, I went back and re-did this problem and got (3/2)r^2(sqrt(3)). I solved for the area of one equilateral triangle using r as one of the sides, multiplied it by six, and then reduced it to what is above.
9K
  • · Replies 33 ·
