MHB What is the area of square ABCD with OQ = OF = 6?
  • Thread starter Thread starter maxkor
    Area Square
The area of square ABCD can be determined using coordinate geometry, given that OQ and OF both equal 6. By establishing a coordinate system with O at the origin, the calculations reveal that the midpoint M of line segment HK is crucial for determining the dimensions of the square. The derived relationships between the coordinates lead to the conclusion that the side length of the square is equal to the square root of 12. Consequently, the area of square ABCD is confirmed to be 12. A purely geometric solution is desired but not provided in the discussion.
maxkor
Find area of square ABCD if OQ=OF=6.
Mathematics news on Phys.org
Here is an outline of a solution using coordinate geometry.
[TIKZ][scale=1.5]
\coordinate [label=above right:{\textcolor{blue}O}] (O) at (0,0) ;
\coordinate [label=above right:{\textcolor{blue}A}] (A) at (0,3.46) ;
\coordinate [label=above right:{\textcolor{blue}B}] (B) at (1.73,0.46) ;
\coordinate [label=above right:{\textcolor{blue}C}] (C) at (4.73,2.19) ;
\coordinate [label=above right:{\textcolor{blue}D}] (D) at (3,5.2) ;
\coordinate [label=above right:{\textcolor{blue}F}] (F) at (6,0) ;
\coordinate [label=above right:{\textcolor{blue}H}] (H) at (5.91,1.02) ;
\coordinate [label=above right:{\textcolor{blue}K}] (K) at (1.02,5.91) ;
\coordinate [label=above right:{\textcolor{blue}Q}] (Q) at (0,6) ;
\coordinate [label=above right:{M}] (M) at (3.46,3.46) ;
\draw [blue, ultra thick] (A) -- (B) -- (C) -- (D) -- cycle ;
\draw [brown, ultra thick] (H) -- (K) ;
\draw [blue, ultra thick] (F) -- (O) -- (Q) ;
\draw [blue, ultra thick] (F) arc (0:90:6) ;
\draw [brown, ultra thick] (K) arc (135:315:3.46) ;
\draw [thin] (A) -- (M) -- (3.46,0) ;
\draw [thin] (K) |- (M) |- (C) ;
\draw (0.9,4.7) node {$s$} ;
\draw (2.2,3.6) node {$s$} ;
\draw (-0.2,1.7) node {$t$} ;
\draw (1.7,-0.2) node {$t$} ;
\draw (3.3,2.8) node {$u$} ;
\draw (4.1,2.1) node {$u$} ;
\draw [thin, dashed] (A) -- (C) ;
\draw [thin, dashed] (B) -- (D) ;
\foreach \point in {O,A,B,C,D,F,H,K,Q} \fill [blue] (\point) circle (2pt) ;
\fill (M) circle (2pt) ;[/TIKZ]
Choose a coordinate system with origin at O, so that F is the point $(6,0)$ and Q is $(0,6)$.
I assume that the brown part of the diagram is meant to be a semicircle and its diameter. Let M be the midpoint of HK, with coordinates $(t,t)$, so that the semicircle has radius $t$. Then the line HK has equation $x+y = 2t$. Let K be the point $(t-s,t+s)$. The distance KM is $t$, from which it follows that $t^2 = 2s^2$. The condition that K lies on the blue circle of radius $6$ is $(t+s)^2 + (t-s)^2 = 36$, from which $3t^2 = 36$ and hence $t = \sqrt{12}$.
Next, let C be the point $(t+u,t-u)$. The centre of the square ABCD is the midpoint of AC, namely $\bigl(\frac12t+ \frac12u, t - \frac12u\bigr)$. You can then calculate that B is the point $\bigl(\frac12t,\frac12t-u\bigr)$ and D is $\bigl(\frac12t + u,\frac32t\bigr)$. The conditions that B lies on the brown semicircle and that D lies on the blue circle both lead to the same equation $2u^2 + 2ut - t^2 = 0$. Therefore $u = \frac12(\sqrt3 - 1)t = 3-\sqrt3$.
Knowing $t$ and $u$, you can then easily check that the distance AB is $t$. So the area of the square ABCD is $t^2 = 12$.
I would much prefer to have a solution using a purely geometric argument, but I do not see how to do that.
Hint:
Solution pure geometry:
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
