Area of trapezoid formed by slicing a cylinder
The area of the trapezoid formed by slicing a cylinder of radius R with a plane inclined at an angle α is a complex geometric problem. The trapezoid's dimensions depend on the projection of the cylinder in both the x and y axes, leading to a need for integration to accurately calculate the area. The area of the base of the cylinder is given by Abase=π*R², while the length of the path of the magnetic flux is L. The discussion emphasizes that the resulting shape is not a true trapezoid but rather a truncated ellipse, complicating the area calculation.
  • Understanding of basic geometry and trapezoidal area calculations
  • Knowledge of integration techniques, specifically Simpson's Rule
  • Familiarity with trigonometric functions and their applications in geometry
  • Concept of projections in three-dimensional geometry
  • Study the integration of geometric shapes, focusing on elliptical and trapezoidal areas
  • Learn about the application of Simpson's Rule in calculating areas under curves
  • Explore the relationship between inclined planes and projections in three-dimensional geometry
  • Investigate the properties of ellipses and how they relate to cylindrical sections
Mathematicians, physics students, engineers, and anyone involved in geometric modeling or fluid dynamics applications related to cylindrical shapes and inclined planes.
  • #31
magnetpedro said:
In my opinion it is not. It's a trapezoid because a flux would cross all the length of the cylinder.
Now your talking about the projection of a cylinder into a plane, I believe. The projection would have two parallel sides corresponding to the sides of the cylinder with elliptical end caps. (Whether a projection or a slice at some non-zero angle, you don't get a trapezoid.)
Does the flux pass through the entire cylinder?
Mathematics news on Phys.org
  • #32
Yes, it does!
  • #33
Then, I guess you are asking about a projection, which is a long rectangle with the short ends replaced by half an ellipse. If you have a small light source across the room, it's the shadow cast by a soup can near the wall.
