Area of Two Functions: Find the Answer!
  • Topic:
  • Thread starter Thread starter Petrus
    Area Function
7 replies · 3K views
Petrus
Hello MHB,
Decide area of the two function
$$y^2=x+1$$ and $$y=-x+1$$
progress:
first I equal them to see where they intercept and get $$x=0$$ and $$x=3$$
then I do integrate
$$\int_0^3 \sqrt{x+1}-(-x+1) = \frac{37}{6}$$ which is not correct answer, What I am doing wrong?
Regards,
$$|\pi\rangle$$
Re: area of two function
Petrus said:
Hello MHB,
progress:
then I do integrate
Regards,
$$|\pi\rangle$$
Hi Petrus!
You're integrating the wrong area.
Can you make a drawing?
That should clear things up.
I like Serena said:
Hi Petrus!
Hello I like Serena,
does not make clear when I draw it but I don't see what I am doing wrong:S
When I make it $$x=y^2-1$$ and $$x=1-y$$ so we got $$x=-2$$ and $$x=1$$ we got
$$\int_{-2}^11-y-(y^2-1) = \frac{9}{2}$$ which is correct. I guess my x limit is wrong and I don't see how
Regards,
$$|\pi\rangle$$
Regards,
$$|\pi\rangle$$
Ok. Let me put in a picture then.
You integrated the upper-right area in the parabola, which is also bounded by x=3.
But the lower-left area inside the parabola is needed.
I still find it hard to see if I calculate the correct area now when I think about it.
Do you understand that you need the bottom-left area, which is completely enclosed by the 2 curves?
I understand that we want this area
Edit: I think I understand now, I think I have confused myself.. I will be back if I still got problem, Thanks once again for the help I like Serena!:)
Regards,
$$|\pi\rangle$$
Good.
In your initial integral, you took $y=\sqrt{x+1}$, which is the top half of the parabola.
And you subtracted $y=-x+1$, which is the line, that now counts as the bottom.
Then you did so for each x between 0 and 3.
This is the upper-right part inside the parabola.
In your second, correct, attempt, you took $x=1-y$, which is the line, which now counts as the boundary on the right.
And you subtracted $x=y^2-1$, which is the left part of the parabola.
This is the proper bottom-left part inside the parabola.
See for instance this page with more pictures (and explanations).
