Arithmetic Series help (AS Level)
  • Thread starter Thread starter CathyLou
    Arithmetic Series
The discussion focuses on solving an arithmetic series problem involving the first three terms defined by (12-P), 2P, and (4P-5). The user seeks help with finding the value of P, which is determined to be 7. Following this, they confirm that to find the sixth term, they can substitute P into the equation to find the common difference, d. For the sum of the first 15 terms, the user is advised to use the general term formula, while part (d) can be approached by testing values for n to find terms less than 400. The conversation emphasizes the importance of showing work to receive effective assistance.
CathyLou
I'm totally stuck on the following question and so I'd very very grateful if someone could please tell me how to work it out.
The first three terms of an arithmetic series are (12-P), 2P and (4P-5) respectively, where P is a constant.
(a) Find the value of P.
(b) Show that the sixth term of the series is 50.
(c) Find the sum of the first 15 terms of the series.
(d) Find how many terms of the series have a value of less than 400.
Thank you.
Cathy
You have to show some work in order to get help.
Present us some of your work. Write down the expression for the general term of an arithmetic sequence, and everything should be more clear. Set up a few equations, and see where they'll bring you.
Edit: late again. :smile:
Before I posted I had written the following in response to part a:
an = a1 + (n - 1)d
d = 2p - (12 - p)
d= (4p - 5) - 2p
2p - (12 - p) = (4p - 5) - 2p
4p = (4p - 5) + (12 - p)
Then I got d = 7 but I got confused over the value of p.
Am I working on the right lines?
Thanks for replying by the way! :smile:
Cathy
No, p should equal 7.
Oh, okay, I get where I went wrong. Thank you.
So, for part b do I just substitute in p to the equation to find d?
Cathy
Cathy
Yes, you do. I.e., d must equal a3 - a2, and a2 - a1, doesn't matter which difference you take.
Thanks for your help.
I've now worked out parts a, b and c but I'm still unsure how to do d. Any hints would be really appreciated.
Cathy
Basically, you can solve part (d) unformally by trying to plug in different numbers n into an = a1 + (n - 1)*d and see which one is the greatest term which is less than 400.
Okay, thanks very much! :biggrin:
Cathy
