Arranging this expression into a laplace transform
22 replies · 3K views
tranceical
Hi Guys,
I have an expression that i am struggling to manipulate into a laplace transform. This expression should fit one or a combination of the common transform pairs. I believe the transform the expression should be fitting is either a unit step 1/s a unit ramp 1/s^2 an exponential 1/s+a or a combination.
Please find the expression and my attempt attached. I multiplied through to simplify and leave multiplied terms in the denominator so i can split the fraction for partial fractions (if necessary)
Please could you give me a nudge in the right direction from here? Can i split the fraction to:
r(ei(s))/[sL1+(r/1+src)]
and
r(ei(s))/(1+src)
and try to arrange into two laplace transforms from there? Or is there a another way i can get the original expression into the laplace form?
Please note: i have values for Ei, R, L and C which i can input at some point.
I hope this isn't too unclear, i would really appreciate any help/tips you can give me. Many thanks
It looks like you already have the transfer function in the Laplace domain. So are you looking to find the time domain response of the system to some Laplace domain input function ei(s)? In other words, taking the inverse Laplace transform? If so you'll need to specify what ei(s) is.
Note that your transfer function alone can be simplified via algebraic manipulation to the form:
$$G(s) = A \cdot \frac{1}{s^2 + \frac{1}{\tau}s + \omega_o^2}$$
Plugging in your actual values of R, L1, and C will tell you whether the roots of the expression in the denominator will be real or complex, and that will tell you whether to expect exponential or sinusoidal (oscillatory) terms in the transient response (response to an impulse or step as input).
Absolutely, i have a step input of 0.01v and my other values are R=100ohms L=0.5henrys and C = 0.001 farads. I am trying to understand this function
It looks similar to functions from the table I'm working from (I've attached it) could you show me which time function from my table i need to aim for? Then i should do partial fractions before inverse transforming to find the transient response?
Thanks a lot for your help!
So your stimulus, in the Laplace domain, is B/s, where B = 0.01. That makes your response:
$$F(s) = A \cdot \frac{1}{s^2 + \frac{1}{\tau}s + \omega_o^2}\cdot\frac{B}{s}$$
The first thing you'll have to do is hammer your original transfer function expression into the form of G(s), so you'll have the expressions for A, ##\tau##, and ##\omega^2##. That's just algebra :smile: Note that this G(s) corresponds to the transfer function of an RLC circuit. What you don't know yet is whether the response will be underdamped, critically damped, or overdamped. That depends upon the component values and thus the roots of the characteristic equation...
So plug in your component values and see if the denominator of the transfer function is going to have real or complex roots (I vote for complex at this point, looking at your component values). Complex roots will imply some amount of oscillation along with exponential decay. Figure on decaying sine and cosine terms. If that's the case, you can rework G(s) into a form fitting either a damped sine or a damped cosine transform or both --- probably both (see your table). That's going to involve some possibly tricky partial fraction work.
So, small steps then. Tell us what you get for G(s) and the roots or the denominator.
Thanks a lot for your help gneill, i'll follow your steps and get back to you.
Please could you explain what tau in the denominator represents/means? In my notes the inverse transform examples haven't ever got too complicated so I'm hoping it won't be a damped sine and damped cosine!
I chose the variable names ##\tau## and ##\omega_o## because they happen to have relevance to the problem at hand. I happen to recognize the form of the transfer function and the type of the differential equation it "belongs" to, so I suppose I had an unfair advantage there :smile: However! You can use whatever variable names you wish, or pick them out of a hat if you like. The mathematics will be the same. ##\tau## is generally used to denote a time constant of some form, and can appear in a damping term. ##\omega_o## is usually the natural frequency of a system that is prone to oscillations.
I'm afraid you'll be looking at damped sine and cosine here... sorry about that! If you haven't done any examples or problems with them yet then I think that this problem is a bit of a nasty way to get introduced to them.
Thanks Gneill. Attached is my attempt at the algebra to get the expression into the g(s) form. I'm wondering if you can tell if if I'm close or on the right track?
If the Tau term was somehow made to be 1/Tau rather than 2(tau), the ei(s) extracted, making the remaining numerator A then it would be ok?
The algebras been a struggle.
Hmm, I'm not "getting" where you're going with your algebra.
You can make your life a bit easier if you set aside the ei(s) to begin with (since it'll just introduce an E/s multiplier, where E is the magnitude of the step) and concentrate on reworking the form of the transfer function.
$$G(s) = \frac{\frac{R}{1 + s R C}}{s L + \frac{R}{1 + s R C}}$$
May I suggest that you begin by multiplying the top and bottom by ##1 + s R C##? That'll immediately reduce the transfer function to:
$$G(s) = \frac{R}{(1 + s R C) s L + R}$$
Then just expand the denominator and work towards the form I showed previously.
Would negative squared and what I've done be a valid match for the form you've suggested? :blushing: If not i will keep trying. Apologies for my poor algebra. Thankyou for your continued help and patience.
Neither do i, there was no mathematical foresight...I have just been multiplying through by all sorts and seeing what it resulted in. I was trying not simplify too much because then i would have more terms to play with. Oh i don't know :blushing:
You want to get the s2 term to have a coefficient of 1. So take your second line and divide through top and bottom by LRC. Don't worry about making the numerator a tad more complicated, it's just a constant and will turn into something excellent later :wink:
After multiplying through by LRC it leaves me (1/LC)/[s^2 + (s(1/RC)) + 1/LC]
Which leaves just the ω term 1/LC that i need to square. So i can write (√1/LC)^2 ? Then on to the partial fractions...
I'm still keen to learn how this problem is solved it's just a shame I've needed so much help with it, so much so that i don't think i can justify submitting it as my own work. Let me be as brainy as you one day :smile:
Yeah, just go ahead and define the constants ##ω_o = 1/\sqrt{L C}## and ##\tau = R C##. Note that you should use ##ω_o## rather than just ω. The reason for this is that the oscillation frequency of a damped system, ω, will be slightly off of the natural frequency ##ω_o##, mainly because the damping extends the time that it takes for the system to return to the equilibrium point (like friction slowing a sliding object). This will become apparent in a bit.
You can calculate values for these constants. The natural frequency should end up with units of radians per second. ##\tau## will be in seconds.
Write out the characteristic equation (the denominator) with the constant values plugged in (you can drop the units for this). Will the roots be real or complex?
"Will the roots be real or complex?" complex... so in this scenario I should multiply out the denominator of the damped sine function to s^2+2as+a^2+omega^2...find my a and omega values, then partial fraction (remembering to add in the b/s from earlier) to form the damped sine and cosine functions?
Many thanks
Many thanks
Yup. That's the plan.
I found a = 5 and omega = √2000-a^2 = 44.44
Then inputting step input, my partial fractions were:
A/s +(Bs+C)/(s+5)^2+(44.44^2)
The result:
[-78.2/s + (78.2)s+782] / (s+5)^2 + 1975
Doesn't seem correct to me...
The result:
Yeah, your a and ω look fine, but something went awry with your partial fraction expansion. Can you elaborate a bit on your work there?
Heres my working (sorry its rough)
Many thanks
Okay, looks like you might have not multiplied the "s" through the whole denominator in your first line.
Symbolically, your Laplace domain response looks like:
$$R(s) = ω_o^2 b \left(\frac{1}{s}\right) \cdot \left( \frac{1}{(s - a)^2 + ω^2} \right)$$
Leaving off the leading constants for now, the partial fraction expansion becomes:
$$\frac{A}{s} + \frac{B s + C}{(s - a)^2 + ω^2} = \left(\frac{1}{s}\right) \cdot \left( \frac{1}{(s - a)^2 + ω^2} \right)$$
Now, if you combine the terms on the LHS by putting them over a common denominator, both sides will then have the same denominator. Equate like terms of the numerators. Bonus! The right hand side's numerator is just 1.
Thanks a lot for help with this problem, it's much appreciated.
I see an error in your first line in the first attachment. Looking through the thread it is not clear that it has been caught.
you need to have A*1975 after clearing the denominator.
