Are Particles or Fields More Fundamental in Quantum Mechanics?
In summary, the author of the article claims that there are no particles, only fields. However, he admits that QFT doesn't solve the measurement problem and that the article is at a more advanced level than its beginner companion book.
atyy
3,374
This thread continues the discussion at https://www.physicsforums.com/showthread.php?t=767018
microsansfil said:
Perhaps when you read this kind of articule "There are no particles, there are only fields" on arxiv. Calculate the position is not it already an interpretation ?
This is how I understand the sentence : "But some ph.d. in physics told me that no, that's wrong and when I use the word particle I'm already using an interpretation of QM".
However, I may be wrong.
Patrick
atyy said:
The article is wrong.
bhobba said:
I had a quick look - it looked fine to me.
What was your issue.
Thanks
Bill
atyy said:
In non-relativistic quantum mechanics, there are certainly systems with a fixed number of particles. These are not classical particles. They are quantum particles, which do not simultaneously have definite position and momentum. Thus they do not have classical trajectories.
The matter of interpretation is whether they have non-classical trajectories. In Bohmian Mechanics, they do.
In exact relativistic quantum field theory, it can be argued that fields are more fundamental. Here the quantum particle is an excitation of the field. However, no one can guarantee that relativity is exact, so even to explain relativistic phenomena, quantum mechanics with a fixed number of entities is viable, as in lattice gauge theory.
atyy said:
The abstract claims "As this paper shows, experiment and theory imply unbounded fields, not bounded particles, are fundamental." That is wrong. Experiment only goes up to a certain energy, and has a certain precision. Claiming to know the final theory is as much pseudoscience as all the things he criticizes.
For example, can he distinguish exact relativistic theories defined in infinite volume from a lattice gauge theory with fine but finite lattice spacing in large but finite volume? The Hilbert space of the latter is finite dimensional, and so more like quantum mechanics than quantum field theory.
bhobba said:
Yea - fair point.
But I am sure the author would agree and point out you are reading more into it than intended.
QFT is a deeper more exact theory than standard QM - that's all that's meant - not that its the final theory.
Thanks
Bill
atyy said:
If he is talking about QFT, then it is roughly a theory with an infinite number of particles, or at least a theory in which particles can be created and destroyed. So it is a theory with more than one particle. But he writes "Thus the Schroedinger field is a space-filling physical field whose value at any spatial point is the probability amplitude for an interaction to occur at that point." and "It follows that the Schroedinger matter field, the analogue of the classical EM field, is a physical, space-filling field." That is of course fine for one non-relativistic particle, and a very useful mental image. But given his concern about quantum field theory, this picture of the single particle wave function is one that does not generalize to more than one particle. The wave function of two particles is not in general "space filling" in the sense that he means.
bhobba said:
Indeed, as the Fock space formalism shows. And even deeper, when deriving QFT, one often uses a model of a large number of interacting particles that you take the limit in the continuum.
That does not contradict the infinite particle picture.
A quantum field can be viewed as a field of operators. The space it operates on is spanned by the creation and annihilation operators. Its two sides of exactly the same coin.
I don't think its fine for a single particle. A matter field, just like any quantum field, is a field of quantum operators acting on the creation and annihilation operators. You can't speak of single particles in that formalism.
The paper is not meant to be a rigorous development of QFT. It is meant to be a review article of the idea that quantum fields are a deeper theory than normal QM, and as such explains many of the issues people get worried about with QM.
He freely admits it doesn't solve the measurement problem, but many things like the double slit experiment become clearer.
Also it soon will be published, if it already hasn't been, in the AJP. Articles with glaringly obvious issues are normally not published there, they are vetted thoroughly to ensure that doesn't happen. Of course no process is perfect and some incorrect things can creep through - but I don't think that's what's going on here. Since its explaining highly complex ideas that should really be expressed mathematically in English subtleties are bound to arise. IMHO that all that's going on - overall it is correct.
It's at a bit more advanced level to its beginner companion book - Fields Of Color:
https://www.amazon.com/dp/0473179768/?tag=pfamazon01-20
But if you want a more advanced look again check out:
https://www.amazon.com/dp/9812381767/?tag=pfamazon01-20
The author may have a copy on his site as well - but don't hold me to it.
That QFT explains many of the issues (not all - but many) with standard QM is for me not controversial at all.
Thanks
Bill
OK, so if he's using second quantization, then it is ok to view the Schroedinger ψ as a space filling field. But then that makes his point even stranger - the Hilbert space, which is a Fock space is a space of particles! One can even invent a number operator and show that the number of particles is conserved in the second quantized Schroedinger equation.
If he wants to argue that the Hilbert space is not a Fock space, he has to believe that our universe is described by a rigourous interacting relativistic field theory, which by Haag's theorem does not have a Hilbert space that is a Fock space.
Mate exactly how you recover usual QM from QFT as some kind of limit is beyond my current knowledge.
I am sure it can be done eg:
http://arnold-neumaier.at/physfaq/topics/position.html
But that is beyond my level.
Also this crops up every now and then. One issue is that when someone says there are no particles, only fields thay are not saying QFT doesn't have particles - obviously it does - but they are the excitations of the field, rather than the fundamental thing itself.
Second quantisation is IMHO a really bad way of looking at QFT.
Its simply this. Model the field as an interacting dust where the interaction is between neighbouring bits of dust. One then assumes the dust value (whatever it is) is described by some kind of Langrangian so you have a conjugate momentum, and you apply the standard QM commutation relations to quantise it. Then you take the limit as the dust size goes to zero to get a QFT.
One then imposes certain symmetry conditions on this field to get various field like the EM field. Zee, in his book on QFT, calls this approach Landau-Ginsberg and IMHO is a much better way to view it than so called second quantization.
Thanks
Bill
Demystifier's comments are also relevant.
Demystifier said:
Two (hopefully non-controversial) points:
First, in non-relativistic QFT (used e.g. in solid state physics), wave function is still the probability amplitude for the position of the particle.
Second, in fermionic QFT, the field is not even an observable.
In addition, 3 different concepts are often mixed up: relativistic QM, QFT (which may be non-relativistic), relativistic QFT.
But on the other hand, the semantics of the field operators is described in terms of how they act on Fock states, and the Fock states themselves represent states of particles, right? I mean that the Fock space is a disjoint union of states with 0 particles, 1 particle, etc.
But maybe it's not necessary to introduce Fock space, and simple define the states axiomatically, without mentioning particle states.
Well the books I have read such as Zee start out with an operator at each point and, via the commutation relations, show that the space they act on is the Fock space.
Many books and notes explain it eg:
http://hitoshi.berkeley.edu/221b/QFT.pdf
It would seem that its whole point. A quantum field implies it acts on the space of creation and annihilation operators which is how you get the picture of the particles being 'excitations' of the field.
It a completely different picture than standard QM.
It must however reduce to it - but my knowledge is not advanced enough to understand how its done.
That however doest seem to be be the issue Atty had with Art Hopson's paper.
He claims that viewing it as a fields helps understanding things like the double slit experiment, and I must say I agree.
It doesn't perturb me at all its inherently unobservable - a state isn't either.
Thanks
Bill
In Hobson's description of the double slit http://arxiv.org/abs/1204.4616 (Eq 4), the quantity in his equation is the state vector, which does correspond to the wave function in the first quantized description. It is not the field operator. The field operator used to define the second quantized Hamiltonian can be thought of as a space filling field, but the wave function of more than one particle cannot. If he wants to talk about the matter field evolving, he has to use the Heisenberg picture and talk about the field operator evolving.
One can also see Hobson's error by looking at his Eq 8, following which he says "##\psi(x)## is the Schroedinger field", which is wrong if by Schroedinger field he means the field operator. For comparison, we can look at bhobba's link to Hitoshi Murayama's http://hitoshi.berkeley.edu/221b/QFT.pdf (Eq 31 and 32): "Note that ##\Psi(\vec{x})## is a ##c##-number function which determines a particular superposition of the position eigenstates ##|\vec{x}\rangle##. But it turns out that this ##\Psi(\vec{x})## corresponds to the Schroedinger wave function in the particle quantum mechanics."
Two responses to Hobson and his rebuttal: http://physics.uark.edu/hobson/pubs/13.09.b.AJP.pdf
Again we get back to exactly how does QFT reduce to standard QM eg maybe in some kind of limit it can be.
Also, as I have mentioned before, I think second quantisation is a bad name best avoided, even though the link I gave used that terminology.
Thanks
Bill
There's no limit that needs to be taken to get from the second quantized to the first quantized Schroedinger equation. First quantization is the quantization of particles, second quantization is the quantization of fields. Hobson is using the second quantized Schroedinger equation. The second quantized theory is exactly the same theory as the first quantized theory of identical particles. If you have normal non-relativistic QM with Schroedinger's equation for one or more identical particles, that can be rewritten exactly as a quantum field theory. It is the same theory in two different languages. In the second quantized theory, there is the field operator and the wave function. The field operator can be considered a field in space, because it is just the operator counterpart of a classical field. The wave function is the same wave function as the usual first quantized wave function, and it is not a field in space, but rather it exists in Hilbert space. In Hobson's Eq 8, what he calls the Schroedinger field, presumably meaning the field operator, is not the field operator, but the wave function. So his paper is wrong.
Could anyone explain the following statement by Hobson in his rebuttal: "My argument about the two-slit experiment is: each individual quantum responds to the fact that both slits are open; this cannot be due to any long-distance force (or call it an “interaction” or a “potential” if you don’t like the word “force”) that extends over the distance from one slit to the other. Thus each quantum must come through both slits."?
Why cannot this be due, say, to the Coulomb potential?
What Couloumb potential would that be?
Atoms, molecules etc are electrically neutral.
Thanks
Bill
Come again.
Forget the second quantisation rubbish - its just that - rubbish - well IMHO anyway.
But if it was true, then the claim that the wave-function is some kind of limit of the second quantised matter-field is trivial in the the same way the EM field is a limit of the quantized EM field. However I am not going to argue along those lines because I don't agree that's the correct way to view it.
What's going on IMHO, is you are applying the idea of a quantum field (which is operators at each point) and symmetries to get various QFT's.
For definiteness let's assume we are using electrons in the double slit
Now what needs to be shown is from that description, in some find of limit, the normal Schroedinger equation results so that wave-function is a reasonable approximation to the field. If that's true then there is no issue - it can be viewed as Hopson suggests.
The reference I mentioned previously - Giuliano Preparata - Introduction to Realistic Physics - purports to show just that - see section 4.4 'The "quantum-mechanical" limit of QFT: The Schroedinger wave-function'
However I am not conversant with QFT enough to say for sure its analysis is valid - although it looks OK to me.
Thanks
Bill
But they can possesses dipole moments. I'm not sure if this is what akhmeteli was thinking about?
But if it was true, then the claim that the wave-function is some kind of limit of the second quantised matter-field is trivial in the the same the EM field is a limit of the quantized EM field. However I am not going to argue along those lines because I don't agree that's the correct way to view it.
Second quantization as a name is rubbish, but that does not mean that the rubbish name names a wrong concept. Second quantization has two modern meanings, both correct.
(1) In non-relativistic quantum mechanics of a fixed number of identical particles, second quantization is translating the Schroedinger equation governing the wave function (first quantized) into a quantum field theory (second quantized). The two forms describe exactly equivalent physics, without any need to take limits or approximations.
(2) Second quantization is the quantization of a classical field. For relativistic particles like photons or electrons, we usually use only second quantized descriptions, and often the first quantized counterparts do not exist as complete quantum theories.
Hobson uses the term "Schroedinger field". So he has already assumed a non-relativistic limit. He would be correct if the "Schroedinger field" he is referring to is the field operator. But when you look at his equations the "Schroedinger field" he is referring to is the wave function. In the link you gave http://hitoshi.berkeley.edu/221b/QFT.pdf Eq 32 contains both the Schroedinger field operator ##\psi^{\dagger}(\vec{x})## and the Schreodinger wave function ##\Psi(\vec{x})##. Hobson mistakenly refers to the quantity that is the Schroedinger wave function as the Schroedinger field operator.
Oh dear oh dear.
I thought these guys would have better sense than to get caught up in metaphysical semantics like the following (from Art Hopson's response):
'He states (paragraph 5) that, “A microscopic entity obeying HUP cannot actually possesses the property of being always present somewhere in space,” and “Whatever its true nature,a microscopic entity is a non-spatial entity.” It is clear from de Bianchi’s letter, from his Ref. 5, and also from the work of D. Aerts referenced therein, that he defines a “non-spatial entity” as an entity that always exists but that does not exist in space-time except when it is momentarily “pulled” into space-time by interacting with a macroscopic detection apparatus. This notion that electrons and photons, not to mention other quanta such as molecules, spend most of their existence residing somewhere outside of space-time is unusual, to say the least. Do molecules reside in space and time only when they are observed? In claiming that electrons and photons do not always reside in space-time, de Bianchi makes one of those extraordinary claims that, as Carl Sagan put it, requires extraordinary evidence. de Bianchi’s only evidence is EPR’s reality criterion. However, this criterion for “reality” is not the only one possible. In fact, the EPR paper (de Bianchi’s Ref. 2) states quite sensibly that “this criterion, while far from exhausting all possible ways of recognizing a physical reality, at least provides us with one such way.” Furthermore, de Bianchi claims the EPR criterion to be both a necessary and sufficient (“if and only if,” paragraph 4) condition for a property to be real, while EPR and common sense recognize it as only a sufficient condition. It is not, as de Bianchi claims, a necessary condition. In other words, a property’s reality does not necessarily imply that the property is predictable. For example, the decay of a nucleus is surely a real event, but it is not predictable. Thus, we cannot conclude, on the basis of the uncertainty principle and EPR’s reality criterion, that quanta reside outside of space-time.'
When not observed QM is silent on properties a system has. It doesn't say it resides outside space-time, in space-time etc etc. It says nothing - its silent.
I still believe the real issue is, in analysing things like the double slit experiment with electrons (photons are a much more difficult animal because they don't have a position) can the wave-function be thought of as some kind of limit of the matter field. If so then the arguments Art uses looks valid.
That's the view of Giuliano Preparata. In fact that's why he wrote the book:
'Most contemporary physicists have no doubt that QFT must be involved in the still mysterious workings of these fascinating phenomena, but, beyond a few phenomenological attempts, such as the Landau-Ginsburg approach, no real headway has ever been made into this kind of physics. And, I contend, the fallacious philosophy of QM is largely responsible for this unfortunate state of affairs. Conversely, couldn't the situation improve, indeed change drastically if we were to realize the centrality of QFT and find that QM is but some kind of approximation of QFT in a well defined, limiting physical situation? This is precisely what this Essay proposes to show'
Now I do not entirely agree with that - but most certainly I do believe many of the difficulties with QM are more naturally approached and understood via QFT than QM.
Thanks
Bill
In the double slit experiment, the assumption is made whatever objects you are using only interacts with the screens, and that only interaction is to be absorbed by it.
If anyone thinks that isn't true then produce your analysis where its accounted for in some other way.
Thanks
Bill
Protons and electrons obey exactly the same Schroedinger equation - but their matter field is entirely different - I am not even sure a protons matter field exists since its a composite particle.
A QFT is NOT taking the Schroedinger equation, treating its expansion of the state in terms of position, as a field, like the EM field, and quantising it. That doesn't even make any sense.
What it is, is considering QFT's in general, is showing that certain types of quantum fields are good models for certain particles, then showing they, in the weak dilute limit, as Giuliano Preparata calls it, Schroedinger's equation is a valid approximation.
Thanks
Bill
Great, so we can just use the Schroedinger wave equation for many identical particles in the non-relativistic limit.
bhobba said:
A QFT is NOT taking the Schroedinger equation, treating its expansion of the state in terms of position, as a field, like the EM field, and quantising it. That doest even make any sense.
The non-relativistic Schroedinger equation governing the wave function for many identical particles can be exactly rewritten as a quantum field theory. This makes sense and is called second quantization. It is certainly not taking the Schroedinger wave function of a quantum theory and quantizing it again, which doesn't make any sense.
It seems obvious that interaction of diffracting particles with the screen can be explained by (or, if you wish, reduced to) their interaction with the particles comprising the screen (by the way, in reality, a diffracting particle can pass the screen, reflect from it or get absorbed in it). Depending on the specific diffracting particles and screen particles, we can have Coulomb interaction, dipole interaction, or something totally different, say, something like Yukawa potential. However, even Yukawa potential, while decreasing fast with distance, does not vanish totally at relatively large distances. That means that particles, such as electrons, neutrons, ions, atoms, molecules carry some fields such as Coulomb field, so they can exchange quanta of that field with the screen. That is compatible with the ideas of Duane and Lande (please see references and comments at https://www.physicsforums.com/showpost.php?p=3724011&postcount=8 ). Even in the case of Yukawa potential I cannot exclude a possibility of exchange of relatively long-wavelength interaction-mediating particles (as a result of a resonance).
Actually, the picture I am describing is close to that of the Couder experiment, which emulates quantum diffraction in classical-physics conditions, and it's clear there that the silicone oil drop passes through one of the slits, but interacts with its own wave on the surface of silicon oil, which passes through both slits.
Another circumstance that makes me wonder if this picture can be indeed reasonable. In my article http://download.springer.com/static/pdf/480/art%253A10.1140%252Fepjc%252Fs10052-013-2371-4.pdf?auth66=1409124342_b333214309d72bc6325575e90f655700&ext=.pdf (published in the European Physical Journal C ) I show how matter field can be algebraically eliminated from the equations of electrodynamics (such as scalar electrodynamics or, with some important caveats, spinor electrodynamics), and the resulting equations describe independent evolution of electromagnetic field. This is also possible if you add some external conserved currents (that can describe the screen). So, say, electron diffraction can be equivalent to some interaction of electromagnetic field with external currents (of the screen).
Doesn't the existence of "states" imply that there are boundary conditions for the fields in addition to something producing field excitations?
Sure, it seems to be a matter of interpretation to bundle what produces boundary conditions and excitations into the concept of a particle (something that isn't specified rigorously). But something besides pure fields is obviously required.
This all seems analogous to the original concept of charge, which was a discontinuity of polarization (a boundary condition for fields and the coupling point between EM force and physical body force).
Of course.
The field is an operator at each point, and the interpretation of that operator is via QM ie its eigenvalues are the possible outcomes of observing it and the Born Rule.
And to make matters worse its inherently unobservable - so it's interpretation is not even subject to verification.
Weird doest even begin to describe it, and an ordinary field it certainly aren't.
That said it still is something assigned to each point in space, which, technically, does make it a field. I think that's the key issue.
And the reference I gave purports to show in the so called dilute limit the wave-function results which gives an intuitive picture in viewing things like the EPR and double slit.
Thanks
Bill
akhmeteli said:
That means that particles, such as electrons, neutrons, ions, atoms, molecules carry some fields such as Coulomb field, so they can exchange quanta of that field with the screen. That is compatible with the ideas of Duane and Lande (please see references and comments at...
Werner A. Hofer has raised similar concerns (even in the slit area) particularly in experiments involving interference of large molecules (see p.8-9):
That a molecule is heated with a laser -most likely leading to excitation of electronic transitions- and then spends microseconds preserving a fictitious state vector related to its translational motion, while shaking rapidly due to vibrational excitations is not credible. Third, it is even less credible that such a molecule, with its time dependent dipole moment, will not induce dipole moments in the slit itself, which then interact with the molecule’s dipole to alter its trajectory.
Elements of physics for the 21st century
http://arxiv-web3.library.cornell.edu/pdf/1311.5470v1.pdf
Having read about these criticisms, I'm still surprised that potentially confounding effects haven't been taken into consideration when doing these type of experiments? I always assumed they were.
Why do you think these are confounding effects? What are they supposed to confound? The double slit is not generally regarded as conclusively demonstrating that reality is nonlocal, so I don't think there is anything to confound.
1. What is Art Hobson's "No Particles" theory?
Art Hobson's "No Particles" theory is a scientific hypothesis that challenges the traditional view of particles as fundamental building blocks of the universe. According to Hobson, particles are merely a convenient mathematical construct and do not have a physical reality.
2. How does "No Particles" theory differ from traditional particle physics?
The main difference between "No Particles" theory and traditional particle physics is the concept of physical reality. Traditional particle physics considers particles to be real objects with definite properties, while "No Particles" theory sees them as purely mathematical entities that do not exist in the physical world.
3. What evidence supports Art Hobson's "No Particles" theory?
One of the main pieces of evidence supporting "No Particles" theory is the phenomenon of quantum entanglement, where two particles can become connected in such a way that their properties are dependent on each other. This is difficult to explain using the traditional particle view, but "No Particles" theory offers a different perspective.
4. Does "No Particles" theory have any practical applications?
While "No Particles" theory is still a scientific hypothesis and not yet widely accepted, it has the potential to revolutionize our understanding of the universe. If proven to be true, it could lead to new technologies and ways of thinking about energy, matter, and the nature of reality.
5. What are the criticisms of Art Hobson's "No Particles" theory?
One major criticism of "No Particles" theory is that it goes against centuries of scientific understanding and contradicts many well-established theories and principles. Some scientists also argue that the theory lacks empirical evidence and is based on philosophical arguments rather than concrete scientific data.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
10K
  • Quantum Physics
