Assumed violation of physics - Heat vs. Work
The discussion revolves around the potential for using an efficient heat engine to power a high Coefficient of Performance (COP) heat pump, with participants exploring the relationship between heat engines and heat pumps in energy conversion. It is acknowledged that energy must be conserved, and the concept of over-unity is dismissed. Participants debate the efficiency of heat engines and heat pumps, noting that an efficient heat engine requires a large temperature difference while a heat pump operates best with a small temperature difference. The conversation highlights the limitations imposed by the second law of thermodynamics, emphasizing that any proposed system must adhere to these fundamental principles. Ultimately, the feasibility of achieving a net gain in energy through this setup remains contentious and is constrained by thermodynamic laws.
  • #51
Crazymechanic said:
@Low-Q , well I believe that what you wanted to make sounds similar to a hydro dam the water goes through the turbine gives it's potential to the turbine and then when it passes out of the dam at the lower side you somehow take it up to the high side of the dam again so that it could do the job one more time and repeat this in a loop but the problem is if you have to bring the water up you have to use energy and in the end the energy extracted from the falling water compared to the energy used to pump the fallen water back up would pretty much equal out. That's why a heat pump or a hydro dam can only create excess energy if the temperature/water difference is supplied by an external force like sun and water evaporation or sun and temperature difference between the two sides of the heat pump and then the pumps has only to move that heat but only in one direction.
Sounds reasonable. You pretty much nailed it :smile:
Science news on Phys.org
  • #52
Drakkith said:
Oh. You are going to be difficult in this manner. Ok then. Let me be clear. You cannot create a temperature difference between two reservoirs if you don't have 2 reservoirs.
OK, that seems clearer.
Comparing that to this:
The heat pump, after you throw it on the table, is now in ONE reservoir.
By "ONE reservoir" I assume you mean the ambient heat in the room the table is in. Yes?
You cannot create a temperature difference with only one reservoir.
By that then you actually mean as modified: "You cannot create a temperature difference between two reservoirs if you don't have 2 reservoirs." Yes ?
The source of my confusion was that I was interpreting your statement to mean: "You cannot use a heat pump to create a temperature difference from just the one reservoir it is in"
After all, it followed directly after your statement "the heat pump... is now in one reservoir"
I hope you can understand the reason for the misinterpretation.
You could argue that it is creating a temperature difference between the input/output sides,
and that would be true
I assume the last statement can stand. I'm content with considering the room the engine is in "one reservoir" and refer to the input and output sides as just that. I assume by "input and output sides" you mean the condenser coils and expansion coils of the heat pump. You do not however consider these to be hot and cold reservoirs. Am I correct ?
Studiot, however, just posted in regard to the same scinario:
If a heat pump is put on a table and switched on, it will just develop one hot plate and one cold plate.
That's true because the heat pump has created a hot reservoir and a cold reservoir.
  • #53
sophiecentaur said:
Where is this thread supposed to be going?
I believe Low-Q would like to use the temperature difference created by a heat pump to run a Stirling Engine, or some form of heat engine directly from the temperature difference and have the engine in turn run the heat pump with excess energy left over to spare to be used for some useful purpose like generating electricity.
That was my impression at the start.
  • #54
Good point. However I am not searching for loopholes in science, just searching for an energysource in the air which a heat pump can harvest in order to power a heat engine. As many links, explanations from you guys has shown, it will not be possible.
Of course it is possible.
But it is just that you can't have a closed system driving itself.
But you could power a heat engine of sufficiently lower power.
The originators of thermodynamics called this a 'self acting machine'
A popular goal was once the idea of extracting heat from the very large heat content of the ocean and converting it to mechanical work to drive the ship. Of course this was proved to be less efficient.
"It is impossible for a self acting machine, unaided by any external agancy, to convey heat from a cold body to a hot one"
There is a clear misconception as to the functioning of refrigeration plant in this thread, which in my opinion has lead to the difficulties with the Tom/Low-Q diagram.
No practical heat pump works by reversing the ideal machine cycle.
There is indeed an 'intermediate' temperature. I will come to that.
I think this is where the misunderstanding has arisen.
Here is a calculation for a perfect refrigerator formed from a perfect heat engine driving a perfect heat pump.
A perfect heat engine takes in heat, Q, at T and rejects heat at T1
Hence
W = \frac{Q}{T}\left( {T - {T_1}} \right)
The perfect heat pump extracts Q2 from the cold body at low temperature T2. It also delivers heat to temperature T1.
Since it is perfect and therefore reversible
W = \frac{{{Q_2}}}{{{T_2}}}\left( {{T_1} - {T_2}} \right)
Where W is the heat equivalent of work given by the heat engine and also the the work used in driving the heat pump.
Hence
\begin{array}{l}<br /> \frac{Q}{T}\left( {T - {T_2}} \right) = \frac{{{Q_2}}}{{{T_2}}}\left( {{T_1} - {T_2}} \right) \\ <br /> \frac{{{Q_2}}}{Q} = \frac{{{T_2}}}{T}\frac{{\left( {T - {T_2}} \right)}}{{\left( {{T_1} - {T_2}} \right)}} \\ <br /> \end{array}
Where \frac{{{Q_2}}}{Q} is the ratio of the heat extracted from the colder body to the heat supplied to the machine reservoir.
Note that the heats (Q2) used in the calculation of the heat pump and the heat engine use heats at different reservoirs, which differ by the work performed.
Using the wrong Q is a common error by beginners.
  • #55
I'm disappointed. You give up far to easily.
  • #56
Tom Booth said:
The heat pump can still operate even if used outside its intended function.
Then it is not operating as a heat pump.
Tom, since you have not provided a reference to an alternative definition, I consider the discussion about the definition of a heat pump closed until you can do so.
This forum is not for personal speculation or personal theories. We only deal with mainstream science. In some cases there are multiple mainstream scientific definitions for the same term, in which case it is worth clarifying which definition is being used, but here there appears to be only one definition. Semantic arguments are boring, so I won't continue with this one.
Tom Booth said:
That is a result of his haste or enthusiasm to use the diagram before I explained it in detail in the other forum. As he did not clarify the nature of the apparent cold reservoir, I have made an effort to do so.
I missed the clarification amidst all of the definition nonsense. Is the cold reservoir not shared?
  • #57
Crazymechanic said:
@Tom , no I don't think we can call those reservoirs...
I don't either.
  • #58
Tom Booth said:
The heat pump in the diagram is maintaining an artificial heat sink within the ambient environment. That is not really a "reservoir". Not in the sense that term is generally used. Naturally, this artificial sink would have to be protected. Insulated. Like an ice box. The only heat entering the ice box would be the waste heat from the engine.
That is exactly what I assumed when I analyzed it above. As I showed above, even for an ideal heat engine and heat pump you would have to use all of the work from the heat engine to run the heat pump. For a real heat engine you will get even less energy and for a real heat pump you will need even more.
  • #59
Well not being a big mathematician but still understanding physics I think that the problem with excess energy extraction from a heat pump /heat engine cycle is that nowhere in nature atleast not on this Earth you have these huge temperature differences from which you could extract a lot of energy , the temperature differences are only minimal and that's why I believe it is really not considered a viable source of energy.
Ofcourse we have huge temperatures in the mantle down below and there were proposed plans for a steam generation/electricty power plant based on that but I guess the engineering challenge and cost speaks for itself.
Not to mention that converting heat to other forms of energy isn't that efficient at all electromagnetism into other forms of energy like mechanical and heat is much more efficient way of converting different forms of energy.So I believe a heat engine is not a very efficient way to run a generator, not to mention the problems associated with running the heat engine in the first place.
This whole idea sounds to me like a self running refrigerator, but we all know that if you want to move something from point "a" to point "b" you need to input energy to do that.If you just let the hot reservoir mix with the cold one without keeping them temperature separated then all you come out is a equal temperature at both reservoirs and the heat pump being useless.
  • #60
I "gave up" because the explanations repeatedly given to me finally sounded reasonable.
I am open to any suggestions that might make this work, but for now (and a few hours to come) I must digest all the information that is already given.
You and me can always discuss this further in another forum.
Equations, reading explanations etc. works not that well for me. I need hands on experience in order to get a good understanding of how things work.
For now it is too expensive to buy a heat pump and a decent heat engine to test this out in practice. So I need some more time to digest all given information, as well as understand where we all disagree or misunderstand each other.
It is hard to be open minded, and be thinking outside the box, while discussing physics with "rational minded" people (No offence to anyone) who mostly do think inside the box - who is referring to most common textbooks.
I'm pretty open minded, but I understand that energy cannot be created from nowhere, nor be destroied. I try to think outside the box without violating common physics...
@DaleSpam: Only dealing with mainstream physics is a huge disadvantage for those more open minded thinkers who want answers to their problem. However, in my opinion, discussions which is all about over unity, perpetual motion, which has nothing to do in this forum, is far beyond being open minded. I think this forum should have enough headroom to allow a discussion take place between pundits and scientists. The main thing to be sure of is that we understand each other's ideas and come to a conclusion that seems rational - and even provable.
Vidar
  • #61
Low-Q said:
To make this work we need a third reservoir. The ground for example. Its temperature will not change as much as the air temperature outside. At very hot or very cold days, the heat engine can be ran by those two reservoires. It powers the heat pump which removes heat from the house at warm days, and supply heat to the house at cold days. Lucky for us, the heat engine will increase its efficiency as the temperature difference is increasing.
So you would use the temperature difference between the air and the ground to drive a heat engine which would power a heat pump to heat or cool a house? I see no reason that couldn't be done.
  • #62
I still don't have any real confidence that you understand the proposal represented by the diagram. If you really want to discuss it I think it would probably be necessary to go back to the beginning.
A mathematical analysis might prove to be quite interesting and useful but so far you have chosen figures that seem inapplicable to the scenario described, so I'm not sure you really understand the proposal.
It doesn't seem to me that you can really prove that x - y = 7 by showing that q - z = 12.
You may be right but the argument is not convincing when you appear to be solving for a situation that wasn't suggested. It seems like your just throwing numbers around in a broad sweeping dismissal.
For example, after looking at the image you said: "In that image the heat pump and the heat engine share both the same hot reservoir and the same cold reservoir. Everything in my posts 5 and 8 applies"
In #5 you begin by saying: "Assuming that the cold reservoir is a typical 300 K temperature,..."
In 8 you say: "An ideal COP 10 heat pump with a cold reservoir at 300 K could only raise heat to a hot reservoir of 333 K."
It is rather difficult for me to relate this to a scenario that has to do with a heat engine running on ambient heat. The numbers describe a situation that is the opposite of what was being proposed.
You say: "then for 70% efficiency the minimum hot reservoir temperature would be 1000 K."
We need to agree on what these percentages actually represent. Your interpreting the percentages in terms of Carnot efficiency it seems, which was not the intention. Your taking it too literally. The diagram was not intended to be technically accurate just suggestive as originally presented to a lay audience not a scientific community.
Carnot efficiency is on a scale of absolute zero. The percentages on the chart are only meant to represent energy flow. Like if I fill my bathtub to the top it is 100% full. How then can I distribute that 100% for various necessary purposes. The percentages are not intended to plum the depths of the ocean, which by comparison, that is what using Carnot efficiency amounts to.
It seems Low-Q got the answer he was looking for. He started this thread however by quoting me and posting a diagram I drew. Perhaps its redundant and unnecessary at this point, but if anyone thinks it might be worth the bother I wouldn't mind going back and doing some kind of analysis of what was actually proposed in the materials utilized, and maybe put some real numbers on it. Perhaps the conclusion will be the same. i.e. it can't possibly work, but at least the proof would be valid for the actual proposal rather than one turned upside down.
  • #63
In which case you should carry on the process I have been advocating all along.
Using real world data.
Here is an extract from the manufacturers measured and confirmed capabilities of currently available heat pumps, I could buy off the shelf.
Note that the COP values are realistic not pipe dreams.
  • #64
Your response to my post:
This is the crucial misaprension of the thread. There is not an energy source in the air that you can harvest. Afaik, in accepted terminology, you can 'harvest' energy from an energy 'resource' where it is available in some form of chemical, gravitational, thermal, etc. form. Just shuffling the internal energy of a body of air (using an input of energy from some resource) in order to create a temperature difference and then using a heat engine is a pretty pointless exercise. Of course, you can 'power a heat engine' this way but why not use the original energy resource and cut out the (always lossy) middle man? You won't get any more out of the system - as has been ascertained several times.
Is there anything more to the main question of this thread?
  • #65
Around 3. What is the application being analyzed ? Heating a home ?
What does COP actually represent ?
What, from that chart is relevant to the proposal ?
I have no problem with real world data if it is applicable or is somehow relateable to what was proposed but I think the subject needs to be broadened somewhat beyond Heat Pumps and COP. Basically a "heat pump" is the same thing as a refrigerator, a freezer, an air conditioner,... There are many methods for cooling.
In a simple chart it is impossible to do more than be suggestive, so Heat Pump - COP, relatively understandable at a glance but only one possibility.
I has originally sent a PM to Low-Q suggesting that he might want to read Tesla's original paper on the subject crudely represented by the diagram but he didn't have time and as far as I know still has not read it.
Tesla's method of cooling was put forward simply as "By some means or another". Heat Pumps did not exist at the time. As I say, the diagram was only intended to be suggestive not technically accurate.
I think it might be best to make sure we have a clear idea what the intent was. Then it night be possible to consider what the options might be suggested by "Some means or another".
I know what the abbreviation COP stands for but really only a vague idea what it actually means. My impression is that it is very application dependent. How well does the appliance satisfy the requirements. The COP of a vapor-compression unit could be practically doubled if it is utilized for both heating and cooling rather than just one or the other.
If the kids turn up the thermostat the COP is reduced. etc. etc. It seems a rather wild variable to me and somewhat difficult to pin down. Neither am I an HVAC technician.
  • #66
Hey guys, let's be real, were fighting thin air here.I can agree to Low-Q that even with all the academic books and all the knowledge we already have we need to stay open minded , but for someone to be really open minded he needs to know the facts and figures that were made before him because without that basic understanding of physics this new generation is starting to play with magnets and thinking of the so called "free energy" basically a misconception from those who either don't know what their doing or the ones who just enjoy a good laugh when their free energy ideas are being realized by people who thought that the Earth is flat until yesterday.
@Tom without getting into any numbers why don't we talk about the basic concept itself as I believe that all ideas first start off with a thought or concept which is then later if considered realistic , calculated and built if possible.
So by concept , you say that yourself that a heat pump is nothing more than a refrigerator, and that's right well as we know for the fridge to be able to function it needs two things a as good as possible thermal isolation and a energy source to run the pump which then in turn will start to move the liquid that will move the heat from A to B.
So if you ask me I just don't see a way how you could make a heat pump which heats your house already,+ requires a external energy source that moves the heat in and out ,, yet make a electricity generator no matter what you add to the device would it be a heat engine or what not.
To create the heat difference you had to use energy in the first place and now when you have done it you want to get that energy back by dong something further with that moved heat but it just won't do as all devices are lossy and you can never get back as much as you used in the first place.And this basic rule applies to pretty much everything in and around us.
Like I said in my earlier posts you have to have a really huge temperature difference for you to be able to use that and extract considerable amounts of power out of it, just like you have to have a really big water height and displacement difference for a hydropowerstation to get you a considerable amount of energy out of that water, no wonder why they try to build dams on either huge rivers with lots of water flow or between canions which have a huge height and also huge potential difference that will be used to power the turbines.With heat it just isn't the same thing because there aren't such a noticable difference and to create one requires energy. So aren't we just playing with magnets and saying that they don't make "free energy" but then turning them around to hope that something will change?...
  • #67
Exactly.
I have tried to show you, by direct calculation, that the COP and efficiency refer to different ratios, and are not just inverses.
In fact there are two different measures and definitions of COP one for refrigerators and one for heat pumps, which are thermodynamically different.
In a refrigerator we extract as much heat as possible for a given amount of work from the evaporator.
In heat pump we want to maximise the heat obtained from the condenser for a given amount of work.
This leads to different values of Q being used from different points in the cycle to define their COP = Q/W.
This is the last time I will attempt to introduce some reality and reason into this thread.
If you are truly concerned to understand more about the thermodynamics of refrigeration and heat pump cycles read chapter 13 of the book that has been the engineering standard for many years
Engineering Thermodynamics, Work and Heat Transfer by Rogers & Mayhew.
  • #68
That is a reasonable objection. Rather than getting a specific set of numbers to exactly match, we can solve for the general system and just leave it in terms of variables that you can plug in.
Using the same notation as in post 14, the efficiency of an ideal heat engine is again:
\frac{W_E}{Q_{HE}}=1-\frac{T_{CE}}{T_{HE}}
The COP of an ideal heat pump used in heating mode is:
\frac{Q_{CP}+W_P}{W_P}=\frac{T_{HP}}{T_{HP}-T_{CP}}
Because they share both reservoirs we have T_{CE}=T_{CP} and T_{HE}=T_{HP}, and to keep the cold side from heating up we need Q_{CP}=Q_{HE}-W_E. Plugging all of these in and simplifying we obtain:
W_E=W_P
In other words, assuming a perfectly ideal heat engine and a perfectly ideal heat pump the heat pump requires all of the work that the heat engine outputs. It doesn't matter what temperatures you use for your input and output sides, they all cancel out and all of the work from the engine is used by the heat pump.
Of course, for real engines and pumps it will be even worse. The real engine is not as efficient as the ideal engine, so it will generate less work, and a real heat pump has a lower COP so it will require more work.
  • #69
Good evening Dale,
One matter absent from your analysis is the small matter of heat transfer efficiency into and out of the reservoirs.
Your perfect machine analysis is silent in this respect.
  • #70
Hi Studiot, I believe that you are talking about the rate of transfer to the reservoir, not efficiency. Correct? The transfer is passive, so it doesn't use or generate work, so I don't see where efficiency would come in.
  • #71
No I'm not talking about rate of transfer.
Let us say you want to use the heat pump to heat a room, obtaining the heat from the outside atmosphere ( a pretty typical practical application).
1)In order to extract heat from the air to your working fluid you have to pass the air over some sort of heat exhanger. Probably you require to expend energy in a fan.
2)Having picked up the heat, you have to pump your working fluid around in heat pump and perform the compression and expansion cycles.
3)You now know what I'm going to say. Having pumped your hot fluid into the room you need a second heat exchanger/fan to remove and distribute the heat.
I was intending to come round to explaining that the manufacturers only quote the the COP of the heat exchanger using (2) as the work budget. This makes advertising headlines but poor engineering.
  • #72
Oh, I didn't realize that. I thought that the COP was for the whole system, which of course includes all of those other fans and parts that you mention for the work.
Well, all that does is reduce the real efficiency further from the ideal efficiency. Since even an ideal heat engine and heat pump could not gain energy this way, what you mention is just one more way for a real system to perform even worse. Worse than 0 is pretty bad.
  • #73
Are you guys discussing heat pumps from the 80's?
I can buy a heat pump with COP of 6.6 @ +7 degrees C when I want to keep an indoor temperature at 20 degrees C. While it is freezing cold outside, -15 degrees C, the COP is 4.3. The heat pump is said to deliver decent heat, when it is -30 degrees C outside, but the factory guarantee down to -25. It is a Mitsubishi Electric heat pump I have been reading about.
Vidar
  • #74
No, we are talking about ideal heat pumps. An ideal heat pump at those temperatures would have a COP of 22.6.
The ideal would be 8.4.
We are giving the idea the complete "benefit of the doubt" and talking about using theoretically perfect heat pumps. And even then it takes all of the work from the ideal heat engine to run the ideal heat pump.
  • #75
I'm sorry but personally I think these kinds of calculations are a waste of time and entirely meaningless, irrelevant, misleading and frankly ridiculous.
As I said before, your using Carnot efficiency on a scale of absolute zero. Its nonsensical.
We are talking about an engine running on ambient heat. "Free" heat all around us in the air. A virtually unlimited supply that is renewed on a daily basis by the sun and will never run out until the sun itself burns out.
Lets take a "real world" example. Not really "REAL" just using real numbers in a hypothetical situation.
Lets say I build an experimental engine that runs on hot air and it works.
I set up hot air solar panels to help concentrate the heat for the engine. I even set up a heat pump along with the solar panels to add more heat on cloudy days.
The engine takes off. It draws in hot air and blows out cold air and generates electricity. I even set up duct work to use the cold air from the engine to air condition my house.
Day after day goes by and it keeps running day and night. I notice that the heat pump is redundant as it never goes on. It wasn't needed.
I'm sitting pretty. All the free energy I can use.
One day the wind blows my solar collector over. I didn't even notice because the engine kept running just the same without it. Still producing electricity. But now the air conditioning is way too cold.
Earlier I measured the heat in the solar panels at an average of 200 degrees Fahrenheit.
The engine was always utilizing 100% of all the heat the solar panels could produce and sometimes then some. Exhausting cold air into the house at a comfortable 60 degree Fahrenheit, even on balmy summer days.
Now with the solar panels destroyed I take new measurements. The engine is now drawing in 60 degree Fahrenheit ambient air directly. I'm shocked to see that the exhaust is now negative 30 degrees Fahrenheit. Thirty degrees below zero! No wonder the house was getting so damn cold.
What is the theoretical "Carnot Efficiency" of this little miracle engine ?
Unfortunately, I know, the thing didn't cool the air all the way down to absolute zero and the whole apparatus didn't disappear reducing itself to a single Bose-Einstein Condensate particle in the process so it can't be 100% efficient at removing every last drop of heat so that the exhaust air was colder than the dark side of the moon or deep interstellar space.
I'm a little fuzzy on the math and the conversion between Fahrenheit and Kelvin and all that technical stuff.
Based on the data. The "Th" and "Tc". all that complicated math stuff that's all Greek to me anyway.
What's the Carnot efficiency of this engine before and after the destruction of my solar collector ?
  • #76
The calculations are a correct analysis of the scenario. The fact that you don't like the answer doesn't make a bit of difference.
Then please post a scientific reference that says that you can use another temperature scale for these equations.
The thing is that heat engines don't run on heat. They run on differences in heat.
So I gathered.
  • #77
So I gathered.
How about just showing the numbers. You've probably already worked it out in your head.
  • #78
Not totally without justification the heat pump manufacturer will say that he does not (necessarily) manufacture the distribution parts.
An air to water system produces water at a stated temp and COP. What you do with it is then your business.
Further comments.
To transfer heat from the ouside air to the heat pump fluid requires the cold reservoir in the heat exchanger to be be colder than the outside air.
To produce warm air at 20°C require the hot reservoir in the indoor heat exchanger to be warmer than 20°C
Thus neither of these figures can be used for COP calculations.
When making comparisons it should be noted in most cases the work input is performed by electricity.
This is more expensive per joule than some other forms of heating.
So the heat output that derived from the work input will be at higher cost.
  • #79
I like the answers fine. If it's understood what it means. most people don't so its misleading.
It isn't the scale. It's that actual utilization of supplied heat to such a heat engine in practical terms. The 100% of all the heat collected by the solar panels for example is something different from ALL THE HEAT down to absolute zero.
Carnot efficiency does not describe practical utilization of the supplied heat, it describes how much of all the heat. ALL of it. That means if you are talking about a hot air engine running on heat in the air, the engine has to cool the air to absolute zero to be 100% "efficient". The engine could be working great making all the energy anyone could ever need but the Carnot efficiency numbers would make it look like a dog. A waste of time.
We can debate that issue another time. I don't exactly disagree. Let's just say this engine, based on Tesla's concept can evolve its own temperature difference. an ingenious combined heat engine slash cooling system. Let's not worry about the working principle, let's just see some numbers.
  • #80
It is not too unlike this little combined heat engine and cooling system, just scaled up a bit. Different kind of heat engine. Different kind of cooling method.
There is no temperature difference until the engine is started, afterwards it maintains its own temperature difference.
This little bird is a heat engine running on ambient heat and evaporative cooling. Evaporative cooling is also driven by ambient heat. So energy from ambient heat in the air is being utilized to produce both energy output and supply cooling.
Until the engine starts, everything is the same temperature.
This is a little different, yet similar.
Still running on ambient heat and simple evaporative cooling from a damp piece of paper.
  • #81
A device that uses a heat pump to create a temperature difference to drive a heat engine, achieving a positive energy output is a violation of the 2nd law of thermodynamics: a type 2 perpetual motion machine. We don't do perpetual motion machines here. Thread locked.
Likes Wrichik Basu
