Asteroid close encounter: speed at perigee
  • Thread starter Thread starter rickyjoepr
    Asteroid Speed
The discussion revolves around calculating the speed of an asteroid at its closest point to Earth, which is initially 7.25 km/s as it passes the moon's orbit. The professor's solution indicates the speed should be 11.0 km/s, but the user struggles with their calculations, yielding incorrect results. The key issue identified is the need to use meters instead of kilometers for distance and velocity in the calculations, as the gravitational constant G operates in the M.K.S. system. The user learns that after converting units appropriately, they can solve for the final speed correctly. This exchange highlights the importance of unit consistency in physics calculations.
rickyjoepr
an asteroid heading towards earth, has a speed of 7.25 km/s as it passes the moons orbit, kit misses Earth by 5000km. What is the speed at the closest point to earth?
The professor provided us with the solution, which should be 11.0 km/s, however when I do the calculation, using the given values, my number is way off.
Is there a conversion I should be doing that I may not know about?
Conservation of energy for an asteroid is
(.5) mVi^2-((GmMearth)/Ri) = (.5) mVf^2-((GmM_earth)/Rf)
Vi = 7.25 km/s
Ri = distance from the moon to Earth = 384,000km
Rf = radius of Earth + 5000km = 11400km
Mearth =5.972x10^24
G = 6.67384x10^-11
solve for Vf
Vf = SQRT[ Vi^2 + 2GMearth ((1/Rf)-(1/Ri))] = 260475.0801
Vi = 7.25 km/s
Mearth =5.972x10^24
G = 6.67384x10^-11
solve for Vf
In your formulas, you use kilograms which is correct, but you need to use meters and not kilometers for distance as well as velocity (m/sec). The constant ## G ## works in meters, and the energy it computes works in m/sec. Once you solve for ## v_f ## in m/sec, you can then convert it back to km/sec.
Likes rickyjoepr
I thought it was an issue with G, I was trying to convert G to km , but I will try what you suggested
edit: and even if i dd convert G to km, it would still be wrong as the kg Mass of Earth must work with m/s
The energy that your equation ## U=-GMm/r ## computes is in joules, so it is much easier to work with ## G ## in the M.K.S. system as is, and simply convert the velocities and distances, and convert ## v_f ## back at the end to km/sec.
Everything worked out, I had been at that for hours, thank you for your guidance. I learned something
Likes Charles Link
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
