Is There a Simple Equation for Hubble's Constant and Time in Astronomy?
  • Thread starter Thread starter Ledsnyder
    Astronomy
An equation relating Hubble's constant and time has been presented, highlighting its simplicity and usefulness. The derived formula, H(t) = H0*(t0/t), represents the Hubble parameter in a matter-dominated universe, based on general relativity principles. However, it is noted that this equation may not always yield accurate results due to the universe's varying dominance of matter and radiation over time. Misunderstandings often arise from the terminology used, particularly the phrase "speed of expansion of the universe," which can lead to misconceptions about the universe's size and the nature of its expansion. Clear communication is essential to avoid these common confusions in astronomical discussions.
Ledsnyder
I found an equation relating hubbles constant and time!It is highly simplified but helpful!
http://www.astronomycafe.net/qadir/q679.html
da/at = (2/3)*a0* (1/t0) * (t/t0)^-1/3
then dividing by a = a0 (t/t0)^2/3 you get
H(t) = H0*(t0/t)
Space news on Phys.org
This is not simplified -- it is the explicit Hubble parameter as a function of time in a matter-dominated Robertson-Walker universe. It follows from the Friedmann and continuity equations of general relativity.
Maybe the simplification is in the fact that it does not always give the right numbers, because our real universe has not been and will not be all the time matter-dominated. It has been radiation dominated for a while in the past, and then kind of a balanced mix for a while. And lately it is gradually shifting over from matter dominance to Lambda-dominance.
The main trouble, though, is what you see if you follow the link. The author refers to this as "the speed of expansion of the universe".
The equation quoted is about H(t). It is not about "the speed of expansion of the universe." People often get confused, it seems to me, when they are told that the universe has a speed of expansion:
1. then they get the idea that it must have a definite known size (else how could it have a speed of expansion?)
2. and they get the idea that this imagined speed must be increasing because they have heard "acceleration" mentioned. (whereas H(t) has been and is expected to continue decreasing).
So they get a bunch of misconceptions that IMHO take root primarily because of careless language.
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
The formal paper is here. The Rutgers University news has published a story about an image being closely examined at their New Brunswick campus. Here is an excerpt: Computer modeling of the gravitational lens by Keeton and Eid showed that the four visible foreground galaxies causing the gravitational bending couldn’t explain the details of the five-image pattern. Only with the addition of a large, invisible mass, in this case, a dark matter halo, could the model match the observations...
Hi, I’m pretty new to cosmology and I’m trying to get my head around the Big Bang and the potential infinite extent of the universe as a whole. There’s lots of misleading info out there but this forum and a few others have helped me and I just wanted to check I have the right idea. The Big Bang was the creation of space and time. At this instant t=0 space was infinite in size but the scale factor was zero. I’m picturing it (hopefully correctly) like an excel spreadsheet with infinite...
