Atkisnon's derivation of \gamma factor.
  • Thread starter Thread starter MathematicalPhysicist
    Derivation
So I am rereading David Atkinson's QFT book:
http://books.google.co.il/books/about/Quantum_Field_Theory.html?id=vbAnQAAACAAJ&redir_esc=y
And I am puzzled by what is written in pages 5-6 section 1.3 Special Theory of Relativity.
He writes down the transformation between two inertial frames, one moving at speed v compared to the other.
x'=\gamma (x-vt) \ y'=y \ z'=z
Now he writes on page 6:
What is gamma?
From the uniformity of space, we see that \gamma may not depend on the coordinates (...).
In the absence of gravity, \gamma is independent of t,x,y,z but it may depend on v.
Rotational invariance therefore means that \gamma must be independent of the sign of v, i.e, it's a function only of v^2.
My problem is with the last conclusion, why can't we have \gamma to be any even function of v, like v^4 and so forth?
any even function of v is a function of v^2.
v^4 = (v^2)^2
Feel so stupid now... :-D
Thanks.
don't feel bad. everybody misses stuff like that at times.
in fact you could come back and ask. really? every even function
of v is a function of v^2? those are two different things in principle,
even functions f(v) = f(-v) and f(v) = h(v^2) for some h.
it's not that hard to prove either.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
