Atomic Clock Time Dilation Experiment
10 replies · 12K views · last reply
HarleyM
Two atomic clocks are synchronized. One is placed on a satellite which orbits around the Earth at high speeds for a whole year. The other is placed in a lab and remains at rest with respect to the earth. You may assume both clocks can measure time accurately to many significant digits.
a)Will the two clocks stil be synchronized after one year?
b) imagine the speed of light is much lower than its actual value. How would the results of this experiment change if the speed of light was only twice the average speed of the satellite? Explain your reasoning using a calculation.
Δtm = Δts/√(1-v2/c2)
a) I calculated the Δtm using a theoretical velocity (3x103m/s) and a theoretical Δts 3.1x107 (about how many seconds per year)
When calculated using Δtm = Δts/√(1-v2/c2) I find no time dilation.. 3.1x107/0.9999999999= 3.1x107
but the fact that the clocks can go to many significant digits worries me, I think they may not be synchronized after the experiment because of the obvious time dilation that will inevitably take place.. any input here would be awesome!
b) using the same theoretical #'s, and changing the speed of light of course, I determined much more time dilation would occur as expected, as objects approach the speed of light time dilation becomes very significant.
Δtm=3.1x107/√(1-1x10-6)
=31,000,015.5 s
significant time dilation as speed becomes closer to speed of light, or in this case speed of light becomes closer to speed of satellite.
Does everything seem logical and ok?
Thanks !
Average speed of a satellite is about 103m/s in orbit
Going by this value, we find that γ ≈ 1
so i don't think there is much difference and that there is any atomic clock that will be able to calculate that ...
SO yes, there is time dilation, but it is not detectable even by the most sensitive of atomic clocks?
Lets say it is not detectable by nearly all of the atomic clocks we have till now ! :biggrin:
What you haven't taken into account is time dilation due to GR. While the clock in orbit will experience time dilation relative to the grounded clock due to the differential velocity, the clock on the ground will experience time dilation relative to the orbiting clock due to the gravitational field.
Yes, 103m/s is the velocity of satellite wrt earth
Looking at the real world GPS, they actually run faster than clocks on earth. Gravitational time dilation is greater than SR time dilation.
From wiki:
For example, the relativistic time slowing due to the speed of the satellite of about 1 part in 10^10, the gravitational time dilation that makes a satellite run about 5 parts in 10^10 faster than an Earth based clock
Did they not include this in the question so that you would be able to mention the fact that there is Time dilation that is noticeable between the clocks? Similar to the early experiments with atomic clocks and airplanes?
I know next to nothing about Physics, just trying to learn myself and that was how I read the question.
thats how I interpreted it as well, but I believe I got the question right. I guess its all about how you explain the answer.
