What Is the Packing Fraction in a Simple Cubic Crystal Structure?
In summary, the conversation discusses the concept of "packing fraction" in a simple cubic arrangement of atoms and how it is related to the density of the material. It also explains how to calculate the largest impurity atom that can fit between the host atoms in terms of diameter. The approach to solving this problem involves calculating volumes and comparing them.
Timiop2008
31
Problem:
A)
In a simple cubic arrangement the atoms sit at the corners of imaginary cubes with their curved surfaces just touching. Show that the ratio of filled space to empty space between the atoms is pi/6 or about 0.5. This "packing fraction" is related to the density of the material. The volume of a sphere of radius r is 4/3 pi r³.
B)
If the atoms in the simple cubic arrangement in part A have diameter d, show that largest impurity atom that can just fit in between the host atoms has a diameter of 0.4d.
Please Help! I don't understand how to approach this Question!
This is really just about calculating volumes. If there are 8 spheres at the corner of a cube what fraction of the volume of each sphere is in the cube. Compare that to the volume of the cube.
A) To calculate the packing fraction, we need to determine the volume of the atoms and the volume of the empty space between them. In a simple cubic arrangement, each atom is located at the corner of a cube and the distance between the centers of adjacent atoms is equal to the diameter of the atoms (d).
The volume of one atom can be calculated using the formula for the volume of a sphere (V = 4/3 πr³), where r is the radius of the atom. In this case, the radius is equal to half of the diameter (r = d/2). Thus, the volume of one atom is V = 4/3 π(d/2)³ = πd³/6.
The volume of the imaginary cube surrounding each atom is (d³), and since there are eight atoms at the corners of the cube, the total volume occupied by the atoms is 8πd³/6.
The remaining volume is the empty space between the atoms, which can be calculated by subtracting the volume occupied by the atoms from the total volume of the cube, which is d³. Thus, the empty space is equal to d³ - 8πd³/6 = d³(1 - 8π/6) = d³(1 - 4π/3).
The packing fraction is then equal to the volume occupied by the atoms (8πd³/6) divided by the total volume (d³). Simplifying this, we get 8πd³/6d³ = 8π/6 = 4π/3. This is equivalent to π/6 or approximately 0.5.
This means that in a simple cubic arrangement, 50% of the space is occupied by the atoms, while the other 50% is empty space between the atoms. This packing fraction is important in determining the density of the material, as a higher packing fraction means a higher density.
B) In order to determine the largest impurity atom that can fit in between the host atoms, we need to consider the space between the atoms. From part A, we know that the empty space between the atoms is equal to d³(1 - 4π/3).
To find the maximum diameter of an impurity atom that can fit in this space, we need to find the radius of the largest sphere that can fit in this volume. We can use the
1. What is the definition of packing fraction?
The packing fraction of an atom refers to the amount of space occupied by the atoms in a given volume. It is the ratio of the volume of atoms to the total volume of the material.
2. How is packing fraction calculated?
Packing fraction is calculated by dividing the volume of the atoms by the total volume of the material and multiplying by 100 to get a percentage.
3. What is the significance of packing fraction?
Packing fraction is important because it gives an indication of how closely packed the atoms are in a material. This can affect its properties such as density, strength, and conductivity.
4. How does packing fraction vary between different materials?
The packing fraction can vary greatly between different materials, depending on the size and shape of the atoms, as well as the type of bonding between them. For example, metals tend to have higher packing fractions than non-metals due to their close-packed crystal structures.
5. How does temperature affect packing fraction?
Temperature can affect packing fraction by causing the atoms to vibrate and move more, which can lead to a decrease in packing fraction. This is because the atoms are taking up more space as they move, resulting in a lower ratio of atom volume to total volume.
  • Classical Physics
  • Quantum Physics
  • Atomic and Condensed Matter
