Attempting to find tension force with electric fields
3 replies · 3K views · last reply
mfgrape123
A small conducting sphere of mass 5.0x10^-3 kg attached to a string of length 20 cm, is at rest in a uniform electric field E. There is a charge of -5.0x10^-6 coulomb on the sphere. The string makes an angle of 30° with the vertical. Calculate the tension in the string. Calculate the magnitude of the electric field.
Probably have to use Fm = BIlsin° Not sure what else, though.
Honestly, I have no idea where to start. We haven't really covered this in class yet, and I don't know what to Google to figure it out that way... Help, please?
Can you draw the free body diagram? What are all the forces on the mass? What do you know about the magnitude and direction of each?
Okay, I think this is the right free-body diagram. I could be wrong, though. But this is the apparatus set-up we're given.
  • Free-body diagram of a ball hanging from a ceiling by a string at 30 degrees from vertical, with a horizontal electric force Fe to the left, tension Ft along the string, and gravity Fg downward.
The OP doesn't say the field is horizontal (so doesn't provide enough info for a solution), but maybe you left that out. So your diagram looks ok. Can you write down the equilibrium equations?
