Augmented Matrix in Echelon Form - One Unique Solution?
  • Thread starter Thread starter L²Cc
    Matrices
In a 3 by 3 matrix in echelon form, a row structured as 0 0 1|3 indicates that there is one unique solution for the variable z, specifically z=3. This configuration shows that the system of equations represented by the matrix is consistent and has a single solution. The discussion also touches on the behavior of matrices with entirely zero rows, which indicate no solutions, and those with one real number equating to zero, which imply infinitely many solutions. Additionally, a technical issue regarding the display of a template in the writing box is mentioned, suggesting that users may need to adjust their settings. Overall, the matrix configuration confirms the presence of a unique solution.
L²Cc
Before anyone comments, the template which you provide does not appear in the writing box for some reason...thus, I'll have to write out my question differently!
When a 3 by 3 matrix is in echelon form, what does it mean when the last row has two zeros on the far right side and two real numbers on the other side so that it looks like this: 0 0 1|3
I know when the entire row consists of zeros, the unknowns have no solutions, when there is one really number and the answer is zero the matrix has infinitely many solutions...I'm guessing the above implies that the matrix has one unique solution? right?
Note that the zeros are on the *left* hand side of the row!
Anyway, yes there is one solution, namely z=3 (supposing you are using coordinates x,y,z, that is!)
oops, human error! Thank you Cristo. Had to clarify...
Are you using the Nexus skin? If this is the case, the template won't show up because it hasn't been implemented in that skin yet.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
