Auxiliary Eqns with Complex Roots
  • Thread starter Thread starter marco101
    Complex Roots
The problem involves solving an initial value problem for a second-order linear differential equation, specifically \(y'' + 9y = 0\) with initial conditions \(y(0) = 1\) and \(y'(0) = 1\). The subject area is differential equations, focusing on the characteristics of solutions with complex roots.
  • Exploratory, Assumption checking
  • Participants discuss the characteristic equation and the roots, noting that they are complex. There is an attempt to confirm the general solution form and to evaluate the implications of the roots on the solution. Questions arise regarding the handling of double roots and the correctness of algebraic manipulations related to the derivatives.
The discussion is ongoing, with some participants confirming the general solution form while others express uncertainty about the implications of double roots and the correctness of derived expressions. There is no explicit consensus, but guidance has been offered regarding the general solution.
Participants are navigating the complexities of the solution process, particularly concerning the initial conditions and the nature of the roots. There is mention of algebraic errors that may affect the interpretation of the solution.
marco101
solve the initial value problem
y''+9y = 0, y(0) = 1, y'(0) = 1
gen solution form is y(t) = C1e^At*(cosBt) + C2e^At*(sinBt)
where A is the real number and B is the imaginary number
i just wanted to check if I am doing this right.
i started off finding the roots,
r^2 + 9
r = +/- 3i
since the real is 0, e would be raised to 0 and become one leaving me with C1cos3t + C2sin3t
r^2 + 9
r = +/- 3i
Yes that is correct. Now find y(0) and y'(0)
since there are double roots, should i make changes to the general solution form? everything cancels out to be zero because y'' = -9cos3t -9sin3t and y = 9cos3t + 9sin3t because it was multiplied by 9 in the original equation.
double roots would mean r=3i,3i or r=-3i,-3i. You have r=0±3i. So yes your general solution is correct.
Also from y = 9cos3t + 9sin3t, y''≠ y'' = -9cos3t -9sin3t , recheck your algebra on that one.
Anyway you take it y= 9cos3t +9sin3t is correct.
  • · Replies 22 ·
