Average speed problem What am I missing?
The discussion revolves around calculating the average speed of a person walking from point A to point B and back, with different speeds for each leg of the journey. The correct approach involves determining the total distance traveled, which is 2d, and the total time taken for both segments of the walk. The time for each leg is calculated as t1 = d/5 m/s and t2 = d/3 m/s, leading to the total time being t = d/5 + d/3. By substituting these values into the average speed formula, the participant realizes that the distances cancel out, simplifying the calculation. The key takeaway is that understanding how to manipulate the equations correctly leads to the solution of the average speed problem.
xXOfNiRXx
A person walks from point a to point b at a speed of 5 m/s. Then she turns around and walks from point b to point a at a speed of 3 m/s. What is her average speed?
Average speed is equal to d/ change in t.
So I know the distance is 2d. I also know the acceleration is constant, though I don't know if I need it for the problem. So I tried to do 5m/s + 3m/s /2 to get the answer. That led to the wrong path. Since we don't have time, I'm assuming that maybe I use a kinematic equation. However, we don't know what acceleration is, other than it is constant.
Here the person is walking with uniform velocity.
From a to b the time taken is t1 = d/5 m/s
From b to a the time taken is t2 = d/3 m/s
Find total time and total distance. Then the average velocity = total distance / total time.
I see that total distance is 2, or 2d. I am having trouble seeing how to get the time.
Total time t = t1 + t1 = d/(5 m/s) + d/(3 m/s)
Tried working it out, but I'm not seeing it here. I see that by manipulation you get t=d/v at which point you plug in the speed that I am given. Can you explain a bit more. I'm quite confused here.
Average velocity = 2d/t = 2d/( d/5 + d/3)
Oooooooo! It all makes sense! Got it! Thanks so much! Really appreciate it. The trick was seeing that the d's would cancel! Thanks!
