Average Velocity: Find Average Velocity of Gas Particles
To find the average velocity of gas particles, the formula used is V = (Σv_i)/N, where V is the average velocity, Σv_i is the sum of the velocities of all particles, and N is the total number of particles. There was a clarification regarding the upper limit of the summation, which should indeed be N. The discussion confirms that using N as the upper limit is correct. This formula is applicable for ideal gases and provides a straightforward method to calculate average velocity. Understanding this concept is essential for studying gas behavior in physics.
God's Pen
Hello:smile:
suppose we have a gas (ideal) inside that gas there are particles (N
particles) and each particle has a certain velocity v.
i want to find the average velocity of all the particles inside that gas.
would it be \mathbb{V}=\frac{\sum_{1}^{n}v_i}{N}
\mathbb{V} the average velocity.
thanks.
God's Pen said:
Hello:smile:
thanks.
Wouldn't the upper limit on the sum also be N?
yes,i meant N,is it okay ?
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
