Axiom of choice question (small index set)
Jerbearrrrrr
Hi there,
just wondering what this could mean:
"Remark: AC is trivial for |I|=1, since A non-empty means \exists x st x \in A. Similarly for |I| finite (induction on |I|)."
I is the index set. As in, our sets are {A_i with i in I}.
I'm really not sure what this explanation is getting at.
Thanks
Mathematics news on Phys.org
For axiom of choice you need to define a function (choice function) with domain I . If I is finite you can define a function by listing all its values. This already can be done based on the other axioms of set theory, so AC is not needed in this case.
Oh right. I thought there was some problem in choosing what the output of the function was.
Okay then, thanks.
If I is countably infinite, you can also specify the function with a list though, surely?
You need a way of deciding what each f(i)=. But even if I is finite, you still need a way of deciding what each f(i)=.
Need help D:
(I understand that the AC isn't needed in choosing from well-ordered sets, so I thought the issue was just deciding how to pick the f(i))
Try working through the details of the one-element index set. How, exactly, do you prove that a choice function exists?
Or, to phrase it differently, how do you prove the set of choice functions is non-empty?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
