MHB Prove A & B Using Axioms & Definitions: Axiomatic Approach 3
  • Thread starter Thread starter solakis1
    Approach
The discussion revolves around proving two statements using provided axioms and definitions. For statement A, participants agree it is straightforward, while statement B presents challenges, especially when considering negative values. There is a debate on whether the absolute value should be treated as an axiom rather than a definition, with arguments highlighting the distinction between notation and axiomatic statements. Participants suggest proving properties of negatives and the multiplicative inverse as part of the solution. The conversation emphasizes the importance of clarity in definitions and axioms within mathematical proofs.
solakis1
Given the following axioms:
For all a,b,c we have:
1) a+b = b+a
2) a+(b+c)=(a+b)+c
3) ab = ba
4) a(bc) = (ab)c
5) a(b+c) =ab+ac
NOTE,here the multiplication sign (.) between the variables have been ommited
6) There ia a number called 0 such that for all a,
a+0 =a
7)For each a, there is a number -a such that for any a,
a+(-a) = 0
8)There is a number called 1(diofferent from 0) such that for any a,
a1 = a
9)For each a which is different than 0there exists a number called 1/a such that;
a.(1/a)= 1.
10) exactly one of a>b,b>a or a=b holds
11) if a>b ,b>c then a>c
12) if c>0 ,a>b then ac>bc
13) if a>b then a+c>b+c for any c
The definitions:
14) a/b = a(1/b)
15) $a\geq 0\Longrightarrow |a|=a$ and $ a<0\Longrightarrow |a|=-a$.
Then by using only the axioms and the definitions above prove:A) If a>0 and b>0 then a>b iff aa>bbB) If $x\neq 0$ then (|x||x|)/x=x for all x
Hi solakis,
What have you tried?
I like Serena said:
Hi solakis,
Hi
A is easy but for B the 2nd part i get stuck
The part were we consider x<0
And another thing
Why should we not consider the definition of absolute value as an axiom and not as a definition
solakis said:
Hi
I guess you mean how to prove that (-x)(-x)=xx?
Perhaps you can prove that (-x)=(-1)x?
Or that (-1)(-1)=1?
And another thing
Because it's a notation.
An axiom would be if the notation is used in a statement.
Similarly (1/x) and (-x) are notations or definitions to identify the multiplicative inverse respectively the additive inverse.
The axiom is that for every x there exists an additive inverse, denoted as (-x), such that x+(-x)=0.
This is a statement.
Or that (-1)(-1)=1?
-,/ are not notations ,but two of the primitive symbols about which we write the two axioms:
a+(-a)=0
$a\neq 0\Longrightarrow a\frac{1}{a} = 1$.
Or in the language of the predicate logic one place operation terms.
Who said that | | cannot be taken as a one place operation symbol and consider as a primitive in our axiomatic system.
Is it not the :
$x\geq 0\Longrightarrow |x|=x$ a statement?
And another thing ,if the above plays the same role in a proof as an axiom why called definition
a+(-a)=0
notation equals primitive symbol.
We call it a definition if it is about a word or a symbol (or set of symbols) that has no meaning yet until we give it a definition.
A definition typically has the form "<word> is defined as <definition>", or "$|\cdot|$ is defined as <definition>", although the exact form can vary.
We call it an axiom if it's a statement making use of the words and symbols we defined, that is accepted as implicitly true.But hey, you don't have to take my word for it if you think you know better.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
