B-Fields: Deriving Faraday's Law & Why No Work?
  • Context: Undergrad
  • Thread starter Thread starter ChanceLiterature
    Work
The discussion centers around the concepts of magnetic fields (B-fields), work done by these fields, and the derivation of Faraday's Law of electromagnetic induction. Participants explore the implications of B-fields on charges and magnetic dipoles, as well as the mathematical formulations related to electromotive force (emf).
  • One participant expresses confusion about the statement that B-fields do no work, questioning whether this is due to the definition of work as path integral only over conservative fields.
  • Another participant clarifies that B-fields do not do work on point charges, as indicated by the Lorentz force equation, which shows that the force from a B-field is always perpendicular to the velocity of the charge.
  • There is a discussion about the closed line integral of B and its implications, with one participant questioning why it is necessarily zero and referencing the divergence of B-fields.
  • Participants note that B-fields can do work on magnetic dipoles, as evidenced by the attraction and collision of magnets.
  • One participant acknowledges a lack of clarity in their understanding of emf and its relationship to B-fields, suggesting that resolving this confusion may help clarify their questions about Faraday's Law.
Participants express varying levels of understanding regarding the work done by B-fields and the implications for Faraday's Law. There is no consensus on the deeper meaning of B-fields doing no work or the conditions under which the closed line integral of B is considered zero.
Participants reference mathematical formulations and principles, such as the Lorentz force and the divergence of B-fields, but do not resolve the underlying assumptions or definitions that contribute to their confusion.
ChanceLiterature
This statement has always confused me. Now my confusion is coming home to roast while we cover EMF.
If we consider work mathematically as ∫f.dl and require integral to be path independent then of course the B-field does no work.
However, it seems like there is a deeper meaning to B-fields do no work. Is there?
Tied into this is faradays law. Faraday's Law can be "derived" from emf (it's in quotes because I understand faradays is first principles). In this derivation emf force is stated to be closed integral ∫E.dl. I do not understand why this why emf or this induced force around the loop is necessarily due to an E-field as opposed to to B-field.
For some clarification I think you are saying that B-field do no work to charges. B-field do work to magnetic dipoles as we see two magnets attract and collide.
it equals to
-\int_A\frac{\partial \mathbf{B}}{\partial t} \cdot d\mathbf{A}
using B.
it equals to
using B.
Yes, I'm trying to highlight two points of confusion. You're right I was not clear enough. I hope this helps.
1) I am asking why B-fields do no work on a point charge when the path integral of a charge on a B-field is non-zero? Did we define work as path integral only over conservative fields? Is this why we say B-fields do no work?
2) I am not sure why the closed line integral of B is necessarily zero (if I still had my copy of Boas' Mathematics in the physical sciences, I might know why/if this holds). Additionally, if it is not necessarily zero, I am not sure why the resulting the emf is defined as closed E.dl.
My confusion with Faraday's law in the original question derives from not understanding emf I suspect. Thus, I think ironing out point of confusion 2 will help
A familiar reply to 1) is to see the formula of Lorentz force the part originated from B of which is
q \mathbf{v} \times \mathbf{B}
and is always perpendicular to velocity of charge q point, ##\mathbf{v}##, thus no work done on the charge.
Thanks. I realized 1 was very dumb after remembering what conservative and close integral meant.
Additionally, even I'm not sure what I'm asking or saying for 2
Thanks for the help
Zero we see as for B is
\nabla \cdot \mathbf{B} =0
and thus
\int_S \mathbf{B} \cdot d\mathbf{S}=0
for a closed surface S. Not line integral.
