What is the concentration of available chlorine in the household bleach?
  • Thread starter Thread starter pivoxa15
    Titration
Household bleach typically contains sodium hypochlorite (NaOCl), with its concentration expressed as 'available chlorine.' In a classroom experiment, students measured the concentration of available chlorine in a bleach sample labeled with 4% (w/v) available chlorine. Through titration with potassium thiosulfate, they calculated the concentration to be approximately 3.95g/100g, aligning with the label's claim. Initial calculations mistakenly focused on chlorine ions rather than the sodium hypochlorite compound itself. The final consensus confirmed that 'available chlorine' refers to NaOCl, not just Cl ions.
pivoxa15
Some brands of household bleach contain sodium hypochlorite, NaOCl as the active ingredient. The concentration of NaOCl in the preparation is recorded as the concentration of ‘available chlorine’. One brand of this bleach stated on the label that it contained ‘4%(w/v) available chlorine’. In an analysis of this bleach, each pair of students in a class measured out 20.00ml from a new, unopened bottle of the bleach. They then made this up to 250.00ml in a standard flask with distilled water, and removed 20.00ml aliquots for a series of repeat titrations. To each aliquot they added 5ml of 1M sulfuric acid and 5ml of 1M potassium iodide. The equation for the reaction that occurs is:
OCl-(aq) + 2I-(aq) + 2H+(aq) -> I2(aq) + Cl-(aq) + H2O(l)
Each sample immediately turned brown due to the production of iodine. The students then titrated this against a previously standardised potassium thiosulfate which was 0.09877M. The mean titre was 17.22ml.
What is the concentration of the available chlorine in the original mixture?
The reaction of the titration is
I2 + (2S2O3)2- -> 2I- + (S4O6)2-
So number of moles of potassium thiosulfate is 0.0017. So there is 0.00085 moles of I2 in the product formed of the reaction
Hence 0.00085 moles of OCl- molecules were formed. 0.00085mole * 35.45g/mole (for chlorine) = 0.03g in the 20ml aliquot. There are 25/2 number of these in the 250ml flask. So 0.3768g in the 250ml flask. This came from 20ml from the bottle so 0.3768g/20ml = 0.019g/ml or 1.9g/100ml of available chlorine hence not even 2%(w/v). But the answer claimed 3.957%(w/w). Who is right?
Cl or NaOCl?
I took the question as asking the available chlorine ions so Cl. I think some of the compounds are in aqeous solution so are in ion forms like OCl-(aq) although I could be easily wrong here.
I had another look at the question and realized ‘available chlorine’ was not Cl but NaOCl. Assuming this, I redid the question again and got 3.95g/100g which is exactly what the answers suggeted. Thanks for pointing out this.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
