ranger
- 2
So I guess we can wrap up circuits D and F?
So what is your final solution?ranger said:So I guess we can wrap up circuits D and F?
NoTime said:So what is your final solution?
Say where the 45 ohm resistor gets connected also.
You could also try to figure out what the op-amp parameter is that you left out of the list before.![]()
After your statement that this solution involves connecting the 240 ohm and zener to the inverting (-) input of the op amp. I have to say your solution is wrong and it's back to the drawing board for you.ranger said:Well my final solution is this:
https://www.physicsforums.com/showpost.php?p=1392945&postcount=83
ranger said:I'm still unsure as to whether the answers to the questions you asked in post #84 are in my post #85 and #87.
I believe the final op-amp property I left out was slew rate.
NoTime said:After your statement that this solution involves connecting the 240 ohm and zener to the inverting (-) input of the op amp. I have to say your solution is wrong and it's back to the drawing board for you.
ranger said:I indicated that it was a typo, and the linked post (#83) states that I have the zener to the non-inverting input. You're beginning to confuse me![]()
berkeman said:** The second issue raised by NoTime is a very important one, and I'll add an extra twist to it. Look at a datasheet for Zener diodes, like this one:
http://www.vishay.com/docs/85763/bzx84v.pdf
What current is the Zener voltage measured at for this small-signal Zener family? What should the resistor in our circuit be, if we were using this Zener series? What would be the effect of chosing a smaller or larger resistor than this?
And for my extra-credit Quiz Question -- how does the temperature coefficient of Zener diodes vary with Vz? What value of Zener diode generally has the lowest temperature coefficient?
ranger said:Well if we want to get the 9V regulation, we could go with the BZX84C9V1-V, which has a range of 8.5V-9.6V. it seems that they are indicating that they got that range by using a test current of 5mA. We are way over that limit here (62mA). We would need to use a bigger resistor to trim the current down to 5mA.
AlephZero said:You calculated the zener current as 15V/240R = 62 mA? Oops...
You forgot the voltage drop across the resistor is (15-9) = 6V which gives the current as 6V/240R =25mA.
I was in a rush to get to my school's library to renew my copy of The Art of Electronics. But they won't let me; they took it away.ranger said:I have to run. I'll see if I can get to the quiz question later.
Now I have to wait till the new semester starts (about 3 weeks). AlephZero said:You calculated the zener current as 15V/240R = 62 mA? Oops...
You forgot the voltage drop across the resistor is (15-9) = 6V which gives the current as 6V/240R =25mA. The BZX series would handle 25mA (the power dissipation is 9x25 = 225mW < 300 mW absolute max) but it's a waste of power and it would change the reference voltage a bit (see the data sheet for dynamic resistance)
See my previous post #98. I admit I didn't look up the zener current in a data sheet for post #98, but my estimate of 5ma current was about right
Re the supplementary question, there's a nice graph near the end of the data sheet that shows the answer. Making sense of the temp coefficients in the tables is a little bit harder to do.
All true.berkeman said:** I think that NoTime may be referring to the limited Iout of most opamps (is that right?), and that would be my fault for not mentioning that I was assuming that we were carrying along the high-current opamp shown in the original 200mA Bad Circuit. Most opamps are not going to give you that kind of output current. The issue of unbalanced input impedances was mentioned by ranger -- where the input bias offset current will generate an error term in the output. This is hard to avoid in this simple implementation, but could be mitigated if the opamp had fairly low input bias current offset specs.
NoTime said:Closer, but I'll give you one equation.
The zener current equation is I_z = (V_source - V_z) / (R_bias + R_z)
R_bias is the 240 ohm resistor.
Zener power disapation is not V_z * I_z.
What is the correct formula?
The zener voltage V_z is not V_ref (junction of 240 ohm and zener).
What is the equation for V_ref?
That would be the modified one you posted in 98.AlephZero said:NoTime, which circuit are you talking about here? The original one, or my modified one (post #98)?
I like thisAlephZero said:One of my former bosses used to say "If you already know something is a dumb idea, don't waste time calculating how dumb it is to 3 decimal places".
The distinction between regulator and reference is only intent and not construction. Selection of different values of R_bias (what I was asking about) causes the reference current to change.AlephZero said:That's the small-signal equation for using the Zener as a regulator. The data sheet give the dynamic resistances R_z at two reference currents. The values only apply for small changes around those reference currents.
In this circuit the Zener isn't a regulator, it's providing a constant reference voltage. If you take the design point I_z = 5ma, all you can say from the data sheet is that V_z is within the tolerance band around the nominal 9.1V value. R_z doesn't come into the calculation of R_bias.
Frankly, the dynamic aspect of R_z is news to me.AlephZero said:If you look at the graph on page 4, you see that R_z is a strongly nonlinear function of I_z and decreases as I_z increases. There is no easy way to calculate the change in V_z if the current changes from 5mA to about 25mA. Using the data sheet value of R_z = 6R at I_z = 5ma in the "small signal" equation won't give the right answer.
The power dissapated by the zener is not 9v * 25ma = 225mW.AlephZero said:Sorry - I don't see what else it could be (assuming I_z is the total current through the diode).
The only formula that I'm aware of for finding the zener impedance is:NoTime said:The distinction between regulator and reference is only intent and not construction. Selection of different values of R_bias (what I was asking about) causes the reference current to change.
NoTime said:The power dissapated by the zener is not 9v * 25ma = 225mW.
Why?
NoTime said:That would be the modified one you posted in 98.
I'm confused as to what I might have said that make you think otherwise.
I'd actually appreciate it if you would point that out.
Why?
Perhaps rewording the question will help.ranger said:We have the current held at a constant 25mA in our circuit.
Try making up an equivalent circuit using a voltage source, resistor (and diode if you wish).ranger said:I can't see why it wouldn't be this. Can you give a couple of hints?
Given that we want IZ to be 5mA, voltage source of 15V, and a zener voltage of 9V for the specific IZ:NoTime said:Perhaps rewording the question will help.
If you were given a 9v zener.
How would you select the appropriate bias resistor?
If we use a regular pn junction diode, the power dissipated is still IF*VF. Translate this to zener, we get IZ*VZNoTime said:Try making up an equivalent circuit using a voltage source, resistor (and diode if you wish).
ranger said:Given that we want IZ to be 5mA, voltage source of 15V, and a zener voltage of 9V for the specific IZ:
[tex]R = \frac{(V_S - V_Z)}{I_Z}[/tex]
[tex]R = \frac{(15 - 9)}{0.005} = 1.2k \Omega[/tex]
I don't see how this helps.
What is the power dissipation in a battery?ranger said:If we use a regular pn junction diode, the power dissipated is still IF*VF. Translate this to zener, we get IZ*VZ
NoTime said:The equivalent circuit of the zener is basically a battery and resistor.
Power dissipated in the 9v zener with a 240 ohm bias is I_z^2 * R_z or about 16mw.
berkeman said:If there is a voltage drop across the Zener and a current flowing through it, it seems like the powers of the external supplies and dissipative elements would force the dissipation of the Zener to be Vz*Iz, and not dependent on the dynamic Rz value.
berkeman said:Interesting. Let me think this through. If I have a 10V voltage source with negligible output resistance, and connect to a 5V zener through a 500 Ohm resistor, then I'll have an Iz of 10mA. The voltage source is supplying 10V*10mA = 100mW to the external circuit of resistor + Zener. The resistor is dissipating 5V*10mA = 50mW, so it would seem that the Zener is also dissipating Vz*Iz = 50mW. If there is a voltage drop across the Zener and a current flowing through it, it seems like the powers of the external supplies and dissipative elements would force the dissipation of the Zener to be Vz*Iz, and not dependent on the dynamic Rz value.
NoTime said:Well that is my point.
The current flowing thru the zener is not (10v- 5v)/500 ohms.
It is (10v - (5v + (I_z * R_z)) / (500 + R_z)
berkeman said:The current flowing through the Zener has to equal the current flowing through the 500 Ohm resistor in my example, since they are in series. And the voltage across the Zener has to be 5V in my example, since it is a 5V Zener, and 5V is being dropped across the series resistor.
NoTime said:Is it 5v? I think not.
Take two equal 10 voltage sources, connect them in parallel.
No current flows.
Take a 10v voltage source a 1 ohm resistor and a 9v voltage source.
The 1 ohm resistor has a 1 volt potential difference across it, will have a current of 1 amp and will dissipate 1 watt.
This is the same situation represented by the zener circuit.
I just looks a little different.
berkeman said:I think you're carrying the voltage source analogy for a passive Zener diode component a bit to far. How about if you replace the passive reverse-biased silicon Zener diode with 8 passive forward biased silicon diodes, each with a Vf of 5V/8 = 0.625V. What is the difference in DC V and I behavior between the two circuits? I think you'd agree that the total power dissipation of the 8*diodes in the Supply+Resistor+8*diodes circuit is 50mW, right?
