Balancing equation - What is the chemical formula of cement?
The discussion revolves around the chemical formula of cement and the balancing of a chemical equation involving limestone and clay. It includes aspects of chemical reactions and the composition of cement, which is relevant to both theoretical understanding and practical applications in construction.
  • Homework-related
  • One participant states that cement is a mixture of calcium oxide, carbon dioxide, aluminum oxide, and calcium silicate, but expresses uncertainty about the exact chemical formula of cement.
  • Another participant questions the characterization of cement as a mixture, suggesting that it may not be entirely correct.
  • Some participants argue that cement's composition is not precisely known and varies for different applications, making it impossible to write a single balanced reaction for its formation.
  • A participant mentions the complexity of the reactions involved in cement hardening and suggests looking up additional resources for more information.
  • One participant expresses frustration about the lack of a definitive answer regarding the chemical formula for cement, questioning the educational approach taken by their teacher.
Participants generally disagree on the nature of cement as a mixture and whether a single balanced equation can be established. There is no consensus on the chemical formula of cement, and the discussion remains unresolved regarding the specifics of its composition.
The discussion highlights limitations in defining cement's composition due to its variable nature and the multiple reactions involved in its production and hardening. There are also unresolved aspects regarding the calculations related to the amounts of reactants needed.
HOFBrINCl
There are 2 parts to this question:
1. If limestone (calcium carbonate) and clay (assume aluminum silicate) are mixed together and heated then the result is cement. Cement is a mixture of calcium oxide, carbon dioxide, aluminum oxide, and calcium silicate. These bags can be purchased at any building supplies store. Write a balanced equation.
2. If the factory has 100.0 kg of clay in its reaction vessel, then how much limestone will they need to exactly react with the clay to produce the cement?
Ok, so the first part is relatively simple, the only problem is I can not find what the chemical formula of cement is... there appear to be quite a few different formulas online. limestone is (CaCO3) and clay or aluminum silicate is (Al2SiO5). Once I find what cement is it will be easy to solve.
I'm a little uncertain about the next part too... ok, so I found out there are 162.05g/mol of Aluminum silicate, which would make 162,050mols of clay in the reaction vessel. So where can I go from here? thanks in advance people
Not sure if it's correct, but in your post it's stated that cement is a mixture.
I will be brutally honest - this is a stupid question. Cement is a mixture of not precisely known composition, as different compositions are required for different applications. There are many reactions taking place and it is not possible to write ONE balanced reaction.
That said, some googling will lead you here:
http://matse1.mse.uiuc.edu/concrete/prin.html
and you will find some of the most important reactions taking part during cement hardening there.
its a stupid question I know, why didn't my teacher just give me what they think the chemical formula for cement is? I think this question is a dead end
81K
11K
10K
