Balancing Redox Equations: Half Reaction Method
  • Thread starter Thread starter Soaring Crane
    Redox
The discussion focuses on balancing the redox reaction of ClO3- and As2S3 in acidic solution using the half-reaction method. The user is struggling to correctly divide the reaction into half-reactions and seeks guidance on the proper approach. They initially proposed ClO3- to Cl- and As2S3 to H2AsO4- and HSO4-, but are uncertain about the accuracy. The importance of balancing hydrogen ions (H+) or water (H2O) to maintain atom equality on both sides is emphasized. Assistance is requested to clarify the correct half-reaction method for this specific equation.
Soaring Crane
I have been staring at the following problem, and I can't seem to get the correct answer. I tried using half reactions and the oxidation number method, but I don't know which works best.
Write balance net ionic equations for reaction in acidic solution.
ClO3- (aq) + As2S3 (s) --> Cl- (aq) + H2AsO4- (aq) + HSO4- (aq)
For the half reaction method, which 2 reactions do I divide this into?
I tried this way,
ClO3- --> Cl-
As2S3 --> H2AsO4- + HSO4-
but I suppose this is wrong.
Any help, especially with the half reaction method, is welcome and needed.
Any volunteers?
Thanks again.
It would seem one needs H+ or H3O+ to balance the equation.
The number of atoms must be the same on both sides.
Also on could use H2O also, as in CaO + H2O -> Ca(OH)2
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
