How to Calculate the Height a Helium Balloon Ascends Using Mass and Density
The discussion focuses on calculating the height a helium balloon ascends using its mass and the density of helium and air. The balloon has a radius of 40 cm, an empty mass of 250 g, and is tethered by a 2-meter thread weighing 50 g. The density of air is 1.29 kg/m³, while helium's density is 0.179 kg/m³. The key to solving the problem lies in determining the mass of the thread in relation to its length h, which is calculated as 25h grams, allowing for further calculations to find the height h.
  • Understanding of buoyancy principles and Archimedes' principle
  • Basic algebra for manipulating equations
  • Knowledge of density calculations for different materials
  • Familiarity with the concept of mass per unit length
  • Learn about Archimedes' principle and its application in buoyancy problems
  • Study how to calculate mass per unit length for different materials
  • Explore the relationship between density, volume, and mass in physics
  • Investigate the effects of atmospheric pressure on buoyancy
Students studying physics, particularly those focusing on fluid mechanics and buoyancy, as well as educators looking for practical examples to illustrate these concepts.
vinamas
A heluim filled spherical balloon with a radius of 40 cm got tied into a uniform thread (uniform density) the threads length is 2 meters and its mass is 50 g the balloon ascends when left and ascends a the thread for h meters before it stabalizes again given the empty balloon's mass of 250 g and the density of is 1.29 kg / m^3 and heluim's density of 0.179 find h.[/B]
I don't really know but I think we need to use Fb and pressure(pascal)
Correct assessment so far. What is the mass per unit length of thread? If the thread is h meters long, what is the mass of the thread?
50 grams as I stated
You stated that, if its length is 2 meters its mass is 50 grams, and I asked, if its length is h meters, what is its mass. Do you see the difference?
Sorry I might have not been clear but 50 grams is the entire thread's mass and the only one give for the thread the problem doesn't give the mass for the length h
The first step in solving this problem is to determine from the information given what the mass of the string is if its length is h, rather than 2 meters.
I cannnot seem to find a way to do that
If 2 meters of the thread has a mass of 50 grams, what is the mass per unit length of thread (in grams per meter)?
25?
vinamas said:
25?
Good. Now, if the mass per unit length of the thread is 25 gm/m, and the length of the thread is h meters, what is the mass (in grams) of the thread (algebraically, in terms of h)?
25 per m-h?
vinamas said:
25 per m-h?
It's 25h grams. So, if h = 2 m, for example, the mass is 50 gm, and if h is 12 m, the mass is 300 gm. Does that make sense now?
yes but how do I find h ?
  • · Replies 62 ·
12K
12K
