What Does the Banach Fixed Point Theorem Mean?
The Banach Fixed Point Theorem states that if a function g is a contraction mapping on a closed interval, meaning it brings points closer together, then there exists a unique fixed point x_0 such that g(x_0) = x_0. The condition for g being a contraction is that the distance between g(x) and g(y) must be less than K times the distance between x and y, where K is a constant less than 1. To visualize this, one can draw a set and observe how applying the function repeatedly contracts it to a single point. The theorem is applied by iterating the function to find the fixed point, as illustrated with the example of solving x = 1/(2 + x^2). Understanding the contraction mapping concept is crucial for grasping the theorem's implications.
sara_87
I really don't understand nothing from the Banach fixed point theorem, i know that it should satisfy:
[g(x)-g(y)]<K(x-y) for all x and y in[a,b]
but i don't even understand what that's supposed to mean?
any help will be appreciated.
thank you.
Mathematics news on Phys.org
The statement is:
Let g be a map (function) which satisfies
| g(x) - g(y) | &lt; K |x - y|
for some real number 0 <= K < 1, for every point x and y
Then there exists one and only one x_0 such that g(x_0) = x_0 (that is: x0 is a "fixed point" of g).
Now, which part don't you understand? Is it the meaning or application of the theorem that confuses you? Is it the distances? The variables?
Basically, the condition says that g is a contraction mapping, that is: if you take any two points x and y, then their images under g will be closer together than the points themselves. Now the theorem states that if you have such a function g, then somewhere there is a point which doesn't move at all.
if there was a question like:
a)use the banach fixed point iteration to solve the equation x=1/(2+x^2)
b)show that the assumptions of the banach fixed point theorem on the interval [0,1]
how would i go about solving it?
No, you don't know that! It should be [g(x)- g(y)]\le k(x- y) where K< 1.
Applying g to two points in the set moves them closer together.
thank you.
Draw a picture! Take a sheet of paper and draw some "set"- that is, some closed curve representing the original set. If you were to apply your contraction map to every point in that set what would happen? Since every point gets closer to every other point, the entire set is "contracted" to a smaller set inside the original set. Now apply your function to every point in THAT set. Again, it is "contracted"- you have a still smaller set. As you apply the function again and again, you get smaller and smaller sets, contracting to a single point. If you were to apply the function to THAT point, it has to go to itself- it is a "fixed point". If you pick x to be any point in the set and apply the function repeatedly, it must "contract" to that same point as all the points in the set- that sequence, x, f(x), f(f(x)), etc. converges to that fixed point.
Technical point which you may ignore: How do we know the "contractions" don't get smaller and smaller so that the set converges to a non-trivial subset and not to a single point? That's why we need "\le k(x- y) with k< 1[/itex] rather than just "< 1". The contraction can never be less that 1-k.
Let F(x)= 1/(2+ x2). Saying that x= 1/(2+x2) is the same as saying F(x)= x, that is, that x is a fixed point. Choose some reasonable value of x, say x= 0.5. (I "cheated" I did a quick graph of 1/(2+ xx) and y= x to get an estimate of where they cross). Now F(x)= F(0.5)= 1/(2+ 0.25)= 1/2.25= .4444. F(.4444)= 1/(2+ 1.975)= 0.4551. F(0.4551)= 1/(2+ .207)= 0.4531. Keep doing that until you get sufficient accuracy.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
