Banked Turn Equation Discrepancy
  • Context: Undergrad
  • Thread starter Thread starter Neptulin
The discussion revolves around the calculation of the maximum velocity for a car navigating a banked turn, focusing on the discrepancies between a participant's derived equation and the formula presented on a Wikipedia page. The conversation explores the components of forces acting on the car and the interpretation of angles in the context of the problem.
  • One participant references a Wikipedia page that provides a formula for maximum velocity on a banked turn, expressing confusion over discrepancies with their own derived equation.
  • The participant believes there may be a mistake in the Wikipedia article regarding the representation of vertical and horizontal components of the normal force.
  • Another participant argues that the angle θ is correctly defined with respect to the horizontal, and thus the normal force's components are appropriately represented.
  • A third participant reflects on their own misunderstanding, indicating they misinterpreted the angle in their vector diagram, leading to confusion in their calculations.
  • There is a suggestion on how to properly format mathematical equations in forum posts, indicating a technical aspect of the discussion.
Participants express differing views on the correctness of the Wikipedia formula and the interpretation of the normal force's components. The discussion remains unresolved, with no consensus reached on which interpretation is correct.
Participants highlight potential misunderstandings regarding the representation of forces and angles, but do not resolve these issues, leaving the discussion open-ended.
Neptulin
I know that Wikipedia isn't the best source, but it was what I could find on the web to check my solution.
I have been trying to calculate the maximum velocity for a car going around a banked turn. What I found online, contradicted my final equation.
The following wikipedia page gives a solution to finding the maximum velocity of a car on a banked turn:
http://en.wikipedia.org/wiki/Banked_turn" .
It ends up with this formula:
:<math>v= {\sqrt{rg\left(\sin \theta +\mu_s \cos \theta \right)\over \cos \theta -\mu_s \sin \theta }}</math>
Edit: I don't know how to post an equation in these forums. For the moment you'll just have to go onto the page and scroll down.
When I tried the solution I got almost the same thing, but the sinθ and the cosθ (not the ones multiplied by μ), in the numerator and denominator respectively for Wikipedia, were in opposite positions in my equation. I have checked and rechecked what I've done, but I think the the Wikipedia page was mistaken in the first step of its solution:
"Once again, there is no motion in the vertical direction, allowing us to set all opposing vertical forces equal to one another. These forces include the vertical component of the normal force pointing upwards and both the car's weight and vertical component of friction pointing downwards:
Ncosθ = μsNsinθ + mg"
It also uses Nsinθ in the expression for horizontal motion.
I think that whoever wrote this article mixed up their horizontal and vertical components for the normal force. If θ is measured from the horizontal, then the vertical component, by what I see, has to be represented by sin (it is always opposite). My questions is this, which is (if either) right? And if it isn't me, then why? Thanks.
I don't see a problem. θ is the angle of the road with respect to the horizontal, thus the normal force makes an angle θ with the vertical.
Makes sense to me.
You know when you spend ages figuring out how to do something, you are told its wrong and spend ages trying to figure out why - and when you ask for help it becomes obvious you messed up the simplest step, that's how I feel.
I drew a vector diagram with the normal and its components separate from the main diagram, and drew θ from the horizontal for the normal, essentially transferring across without thinking. Well, at least time I'll be mindful of this. Thanks for your help.
And now to slink away in shame.
No shame required. Happens to the best of us. :wink:
To post LaTex math formulas on the forum, use the tag "tex" in square brackets instead of the tag "<math>".
Or if you are typing a sentence and want the formula to stay in the same line as your words, use the tag "itex".
  • · Replies 17 ·
