Banked turns; do we use the x component of normal force or gravity?
The discussion centers on the confusion regarding the role of gravity and normal force in providing centripetal force, with differing views based on the chosen frame of reference. In a vertical frame of reference, gravity has no x component, while the normal force does, and vice versa in a frame aligned with the road. The conclusion suggests that the method of analysis may not matter as long as a consistent viewpoint is maintained. However, the alignment of components with the road surface raises questions about their effects on centripetal force. Ultimately, the frame of reference significantly influences the interpretation of these forces.
x86
I am confused on what the correct way to do this is.
In my old physics textbooks, they say that the x component of gravity is responsible for the centripetal force.
However, on the internet and for more advanced topics they say it is the x component of normal force that is responsible for the centripetal force.
Analyzing this myself, it seems like it does not matter which method is used, as long as you pick a specific viewpoint and stick to it.
Does this hold true? Or is one of them more correct than the other? Thanks.
It depends on your frame of reference. In a frame of reference with a vertical y-axis, gravity is vertical and has no x component, while the road is not horizontal, so the normal force has an x component.
In a frame of reference with an y-axis normal to the road, the normal force doesn't have an x component, but gravity does
Likes 1 person
Ah, thank you for clearing this up. It is what I thought.
EDIT: Just to add another question. If the normal force is the Y axis, then gravities X component seems to align perfectly with the road, directly parallel
However, if gravity is the Y axis then it doesn't seem like the normal forces X component is perfectly parallel to the road.
Wouldnt something like that matter?
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
