How Do Cars Propel and Planes Fly with Different Engines?
  • Thread starter Thread starter Mozart
    Car Plane
Cars are propelled by the force generated from burning fuel in the combustion chamber, which pushes the piston connected to the crankshaft, ultimately rotating the wheels. The transmission plays a crucial role in transferring this power to the wheels, allowing for movement and enabling reverse functionality. In contrast, older planes, such as those from WW1 and WW2, typically used spark ignition reciprocating engines similar to car engines, but with multiple engines for increased power. Modern planes utilize gas turbine engines, which can also be adapted for turboprop applications. Understanding these differences highlights the distinct engineering principles behind automotive and aviation propulsion systems.
Mozart
Hello I have a few questions regarding cars and planes.
I don't understand how a car or any locomotive with a combustion engine is propelled. I understand up until how a mixture of air, and fuel is pumped into a cylinder, a piston rises, and the spark ignites the explosion, and then the exhaust port opens allowing for the exhaust to travel somewhere. Does the force created by the explosion go towards the exhaust port, and that is what gives the car its propulsion? Once the thrust is directed in that direction where does it go? I was told once that the transmission is what gives a car its propulsion so I am thinking now does the force end up going to the trasmission? I am just very confused.
I would also like to know how a car reverses, and what allows for this.
As for planes what kind of engines were used on old fashioned ones from like ww1, and ww2? The ones with the propellers. Were they anything like gas turbine engines on modern planes?
Car
1. It is not an explosion in the combustion chamber. It is burning. An explosion can occur but it would damage the engine.
2. The force is applied on the piston which is connected to a crankshaft which rotates the wheels. Try wikipedia or howstuffworks for the basics of a car engine. They explain the car engine basics pretty well.
Planes
Propeller planes normally use spark ignition reciprocating engines aka car engines only they are many in number for high power with some other small differences.
Gas turbines are used as turboprops in helicopters, propeller planes(I think) and jet planes, generation of electricity, etc.
Thank you!
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
