Java Why Are FFT Frequencies Inaccurate in My Java Program?
  • Thread starter Thread starter joseche
    Fft Frequency
The discussion revolves around inaccuracies in frequency detection within a Java program using Fast Fourier Transform (FFT). Initial issues were identified, including the need for a scaling factor and the importance of windowing to avoid spectral leakage. The user improved accuracy by plotting FFT output and adjusting the data range after converting from short to double. Recommendations for window functions, such as Hann or Hamming, were provided to enhance results further. The conversation emphasizes the significance of clean input signals and proper sampling techniques for optimal frequency detection.
joseche
Hi there, I am using a basic java program to identify the frequency of a note captured by the microphone.
The problem is that frequencies don't seem accurate.
Code:
package com.overdrive.FreqFinder;
import java.nio.ByteBuffer;
import java.nio.ByteOrder;
import javax.sound.sampled.AudioFormat;
import javax.sound.sampled.AudioSystem;
import javax.sound.sampled.DataLine;
import javax.sound.sampled.TargetDataLine;
import org.apache.commons.math3.complex.Complex;
import org.apache.commons.math3.transform.DftNormalization;
import org.apache.commons.math3.transform.FastFourierTransformer;
import org.apache.commons.math3.transform.TransformType;
public class AudioInput {
	TargetDataLine 	microphone;
	final int 		audioFrames= 2048;  //power ^ 2
	final float 	sampleRate= 8000.0f;
	final int 		bitsPerRecord= 16;
	final int 		channels= 1;
	final boolean 	bigEndian = true;
	final boolean 	signed= true;
	byte 			byteData[]; 	// length=audioFrames * 2
	double 			doubleData[];	// length=audioFrames only reals needed for apache lib.
	AudioFormat 	format;
	FastFourierTransformer transformer;
	double frequencyTable[][]= new double[12][8]; //12 notes, 8 octaves
	String notes[];
	public AudioInput () {
		byteData= new byte[audioFrames * 2];  //two bytes per audio frame, 16 bits
		//doubleData= new double[audioFrames * 2];  // real & imaginary
		doubleData= new double[audioFrames];  // only real for apache
		transformer = new FastFourierTransformer(DftNormalization.STANDARD);
		System.out.print("Microphone initialization\n");
		format = new AudioFormat(sampleRate, bitsPerRecord, channels, signed, bigEndian);
		DataLine.Info info = new DataLine.Info(TargetDataLine.class, format); // format is an AudioFormat object
		if (!AudioSystem.isLineSupported(info)) {
			System.err.print("isLineSupported failed");
			System.exit(1);
		try {
			 microphone = (TargetDataLine) AudioSystem.getLine(info);
		     microphone.open(format);
		     System.out.print("Microphone opened with format: "+format.toString()+"\n");
		     microphone.start();
		}catch(Exception ex){
			System.out.println("Microphone failed: "+ex.getMessage());
			System.exit(1);
		notes= new String[12];
		notes[0]= "C";
		notes[1]= "C#";
		notes[2]= "D";
		notes[3]= "D#";
		notes[4]= "E";
		notes[5]= "F";
		notes[6]= "F#";
		notes[7]= "G";
		notes[8]= "G#";
		notes[9]= "A";
		notes[10]= "A#";
		notes[11]= "B";
		buildFreqTable();
	public int readPcm(){
		int numBytesRead=
				microphone.read(byteData, 0, byteData.length);
		if(numBytesRead!=byteData.length){
			System.out.println("Warning: read less bytes than buffer size");
			System.exit(1);
		return numBytesRead;
	public void byteToDouble(){
		ByteBuffer buf= ByteBuffer.wrap(byteData);
		buf.order(ByteOrder.BIG_ENDIAN);
		int i=0;
		while(buf.remaining()>2){
			short s = buf.getShort();
			doubleData[ i ] = (new Short(s)).doubleValue();
			++i;
	public void buildFreqTable(){
		frequencyTable[0][0]= 32.7032;  // C
		frequencyTable[1][0]= 34.6478;  // C#
		frequencyTable[2][0]= 36.7081;  // D
		frequencyTable[3][0]= 38.8909;  // D#
		frequencyTable[4][0]= 41.2034;  // E
		frequencyTable[5][0]= 43.6535;  // F
		frequencyTable[6][0]= 46.2493;  // F#
		frequencyTable[7][0]= 48.9994;  // G
		frequencyTable[8][0]= 51.9131;  // G#
		frequencyTable[9][0]= 55.0000;  // A
		frequencyTable[10][0]= 58.2705;  // A#
		frequencyTable[11][0]= 61.7354;  // B
		for (int note=0; note<12; note++){
			for(int oct=1; oct<8; oct++){
				frequencyTable[note][oct]= frequencyTable[note][oct-1]*2;
	public int findNearFreq(double freq){
		double dMin= Double.MAX_VALUE, dc;
		int curNote=0;
			for (int oct=0; oct<8; oct++){
				//calculate the distance
				if( frequencyTable[note][oct] > freq )
					dc= frequencyTable[note][oct] - freq;
				else dc= freq - frequencyTable[note][oct];
				// see if new closer distance
				if (dMin > dc){
					dMin= dc;
					curNote= note;
		return curNote;
	public String noteName(int n){
		return notes[n];
	public void findFrequency(){
		double frequency;
		Complex[] cmplx= transformer.transform(doubleData, TransformType.FORWARD);
		double real;
		double im;
		double mag[] = new double[cmplx.length];
		for(int i = 0; i < cmplx.length; i++){
            real = cmplx[i].getReal();
            I am = cmplx[i].getImaginary();
            mag[i] = Math.sqrt((real * real) + (im*im));
		double peak = -1.0;
		int index=-1;
            if(peak < mag[i]){
                index=i;
                peak= mag[i];
        frequency = (sampleRate * index) / audioFrames;
        System.out.print("Index: "+index+", Frequency: "+frequency+", Note: "+ noteName(findNearFreq(frequency)) +"\n");
	 * Print the first frequency bins to know about the resolution we have
	public void printFreqs(){
		for (int i=0; i<audioFrames/4; i++){
			System.out.println("bin "+i+", freq: "+(sampleRate*i)/audioFrames);
	public static void main(String[] args) {
		AudioInput ai= new AudioInput();
		int turns=10000;
		while(turns-- > 0){
			ai.readPcm();
			ai.byteToDouble();
			ai.findFrequency();
		//ai.printFreqs();
Technology news on Phys.org
Can you give a specific example that doesn't seem to produce good results?
I am producing a sound freq. with my phone and freqs don't match.
Two common possibilities.
1. missing a scaling factor, often of a rational times Pi.
2. input frequency is not an exact multiple of your fft sampling frequency and you are not windowing your data. Check Window function - Wikipedia, the free encyclopedia and Spectral leakage - Wikipedia, the free encyclopedia Try a nice clean single frequency for input, plot the the entire output from the fft and see if you get a nice clean single peak or if you get a broad range of results. If the latter then see if a good windowing function or sampling at an exact multiple of your possible input frequencies will help.
Hi Bill,
I did a few things, first I plotted the output of FFT and found a few things:
1) the peak was always in the second part of the output, which is the mirrored value?, so I only scan for the peak mag in the first halt
2) I divided the casted double from 'short' by 32768, because double works better in that range
Those two things seem to have fixed my code as it is recognizing notes very accurately.
I didn't use a window function although it seems I should ?, if that is the case, which one should I use ?
Thanks
I'm glad you were able to able to get your code working.
There are many more windowing functions now than when I used to do this.
I'd try Hann or Hamming, give your code input signals that are nice clean simple multiples of your sampling frequency and in phase with the sampling, and compare the result with and without the window, see the maximum and plot the whole output. Then I'd progressively try less nice input signals, shift away from the sampling frequency, shift away the phase and repeat the process.
Depending on what your real input signals are going to be, you may or may not need a window if all you are trying to do is get the peak.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
