Basic question from well check the handle
  • Thread starter Thread starter Dumbass5000
In a vacuum, if two objects of equal density but differing mass are thrown at the same speed and impact a hard, non-deformable surface, they would theoretically bounce back at the same angle and speed due to conservation of momentum and energy. However, real-world factors like friction and surface deformation complicate the scenario. The larger rock, while having greater kinetic energy, may also displace more energy upon impact, potentially affecting its bounce. The discussion emphasizes the importance of ideal conditions to simplify the analysis. Ultimately, the outcome is contingent on numerous variables that are often overlooked in theoretical discussions.
Dumbass5000
I'm involved in a little debate, and I'm looking for an answer to this ignant question:
If I've got two objects of equal density but differing mass, let's say a 1 pound rock and a 1000 pound rock, and I throw them at 100mph over a surface such as dirt/grass, achieving equal height and contact angle upon impact with each object, will they bounce the same distance? (for the sake of argument we'll assume this is in a vacuum)
I understand that the larger rock will achieve proportionately greater gravitational potential energy, and therefore proportionately greater kinetic energy, but it seems to me that the larger rock would also expend a greater amount of that energy displacing the Earth upon contact than would the smaller, and would therefore generate less reactive energy (I'm sure that's a totally ignorant way to phrase it) to once again propel it skyward.
Thanks for helping out a Dumbass5000.
heh, grass and dust, are too complicated to be explained by a theory easly.
lets say you have a surface which has no friciton your rocks.(though i think that friction would roughly give the same answer)
also let's say that the surface is hard, and cannot be deformated.
and let's say that the rocks are perfect spheres.
in such conditions, the rocks whould act like a mirror, the angle you drop the rock on the surface, is the same as the angle it will move after the collusion, and the velocity before and after would be conserved.
but i made lots of assumptions... maybe too much of them, but i don't think a simple theory could explain unsimmetric systems...
Hello! Let's say I have a cavity resonant at 10 GHz with a Q factor of 1000. Given the Lorentzian shape of the cavity, I can also drive the cavity at, say 100 MHz. Of course the response will be very very weak, but non-zero given that the Loretzian shape never really reaches zero. I am trying to understand how are the magnetic and electric field distributions of the field at 100 MHz relative to the ones at 10 GHz? In particular, if inside the cavity I have some structure, such as 2 plates...
