Basic question regarding gravitational acceleration
When a 1 kg mass is lifted, it experiences a gravitational force of approximately 9.81 N. To determine the downward velocity of the object when released from a height of 1 meter, standard kinematic equations for constant acceleration can be applied. The velocity can be calculated using V = gt, where g is the acceleration due to gravity. The time taken to reach the ground can be found using D = 1/2 gt². These equations assume no air resistance for simplicity.
Pogo Physics
Hello,
I have a very basic physics question. If I lift a body of mass 1 kg into air, it will be attracted by a downward force F = mg = 98.1 N.
What I want to know is what would be the downward velocity of the object? If I release an object of mass 1 kg from a height of 1 m, with what equation can I find the velocity of the object or the time needed by the object to reach the earth?
Thank you.
I think you mean 9.81 N.
Ignoring complications such as air resistance, the acceleration of a falling body is constant. So you can use any of the standard constant acceleration kinematic formulas. For example:
V = gt (gives the velocity as a function of time)
D = 1/2 gt2 (gives the distance as a function of time)
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
