Basics of using the isolating transformer
The discussion centers on employing galvanic isolation for a differential signal entering an AD620 instrumentation amplifier, specifically within the frequency range of 50kHz to 100kHz and an amplitude of 0.5 volts. Participants suggest using a 1:1 transformer designed for this frequency range, while noting that a 1:1:1 transformer may also be suitable for differential signals. Concerns are raised about the limitations of optoisolators for analog signals, with a preference for digitizing the signal before using optical communication. The importance of decoupling capacitors is mentioned, highlighting their potential role in the circuit. Overall, the thread emphasizes the need for careful consideration of isolation methods based on signal characteristics.
meereck
Hello, I have a differential signal going into an instrumentation amplifier (AD620).
I would like to employ galvanic isolation on the inputs of AD620.
Would anyone be so kind and tell me how it shall be wired?
I don't know much about signal isolation. Shall 1:1 or 1:1:1 transformer be used?
Can I also employ transils for protection - where to place them?
Thanks in advance,
regards Meereck
We need to know a little more about what the input signal looks like. What's it amplitude and frequency, etc.
hello, differentially, it is basically a sine wave in the range between 50-100kHz
Amplitude about 0.5 Volts. I use AD620 for amplifying the signal.
thanks, M.
thanks, M.
50Hz-100kHz, or 50kHz-100kHz? It makes a big difference. If b), then you can use a 1:1 transformer designed to operate in that frequency band. If a), then you will not be able to use a transformer for such a wide range of frequencies. Instead, you would probably be better off isolating the full input amp & ADC circuit, and optically communicating with the ADC to get the data.
How about a linear optoisolator?
Optos aren't linear, generally aren't used for analog coupling. Digitizing first and sending the digital date through an opto would be fairly common.
There were some linear optos a while back (maybe from Linear Technology?), but I don't think they found any volume applications. Pretty pricey chips, as I recall.
Agilent make some.
http://dev.emcelettronica.com/voltage-conversions-galvanic-isolation
3.7 Euros in France..
HCNR201
thanks guys for ideas,
the frequency will be 50kHz-100kHz.
I read something about using 1:1:1 transformer for differential signals. Does it make any difference?
Should some decoupling capacitors be used?
have a nice weekend.
M.
