Basis and dimension of the solution space
3 replies · 18K views · last reply
aleee
Find (a) a basis for and (b) the dimension of the solution space of the homogeneous system of equations.
x - 2y + z = 0
y - z + w = 0
x - y + w = 0
(a)
[1 -2 1 0] => [1 0 -1 2]
[0 1 -1 1] => [0 1 -1 1]
[1 -1 0 1] => [0 0 0 0]
basis = {<1,0,-1,2>, <0,1,-1,1>}
(b) for b i make
x = z - 2w
y = z - w
would i set w = s and z = t?
if so.
[x] = [ t - 2s] = [1] + [-2]
[y] = [ t - s] = t[1] + s[-1]
[z] = [ t ] = [1] + [0]
[w] = [ s ] = [0] + [1]
so the dimension would be the number of vectors
so dimension = 2?
im uncertain about that dimension part
I didn't check your arithmetic, but assuming it is OK try writing your solution like this:
[tex]\left ( \begin{array}{c}x\\y\\z\\w\end{array}\right) =<br /> t\left ( \begin{array}{c}1\\1\\1\\0\end{array}\right)<br /> +s\left ( \begin{array}{c}-2\\-1\\0\\1\end{array}\right)[/tex]
and the answer should become apparent.
You found that the solution of the system is given by
[tex]\begin{bmatrix}x\\y\\z\\w\end{bmatrix} = t\begin{bmatrix}1\\1\\1\\0\end{bmatrix}+s\begin{bmatrix}-2\\-1\\0\\1\end{bmatrix}[/tex]
The vectors multiplying t and s are a basis for the solution space. Your answer to (a) is the basis for the row space of the matrix, not the solution space.
The dimension is just the number of vectors in the basis, so in this case, it's 2.
oh so for (a) i got it mixed up with the basis for the row space
the correct answer is { <1,1,1,0>, < -2,-1,0,1>}
