Bench test AC transformer from stereo tube equipment
In summary: The PAS-2 was introduced in 1960 for $60 as a kit, $80 assembled. I found one in original condition offered for sale (reverb.com) at $575 + shipping. Sounds high but that works out to only 3.5% inflation per year!This information is extremely helpful! I bought this pre amp and sister power amp in 1972. I can't remember whether it was $50 each or $50 for the pair. They got me through college and beyond but were replaced
JohnM24018
I would like to disconnect the secondary windings from a stereo preamp to test the voltages of the secondary windings. The transformer has a 330 - 0 - 330 volt center tapped secondary and a 10.9 volt secondary. It is to be used with house current - 110 or so in Virginia. I have measured the current from the plug. It is OK.
My intent is to use a digital multi meter to measure the voltages of the secondary windings. I intended to measure the 330 leg to zero then zero to the other 330. I was going to test the other windings in the same way.
Is there a better way to do that? If so what is it? Should it be loaded - what ever that is.
The reason I feel this needs to be done is that after some work to the unit all 4 of the 12AX7 tube's pins (#1 and 6) (4 tubes, pins 1 and 6 on each) are currently measuring over 450 volts. They normally measure 115 and 135 volts DC. I tried two meters and got the same results. I see no burns and saw no smoke or sparks. The unit is around 60 years old but has been working recently. I have rechecked my work and am satisfied.
I possesses the sheet from the distributor and could upload it if requested. Some sites prefer me not.
I think it is unlikely to be a transformer fault. It could be measurement error. Just trace the plate voltage back towards the filter caps and rectifier and transformer and see where it comes from.
Actually, 330-0-330 sounds ridiculously high for a pre amp.
The transformer is sold as a PA211 Power Transformer. You seem to be more familiar with these than I. It would be helpful to me if you would search for one of these to check the accuracy of my statements. I could certainly use your experience. I will see if I can upload a photograph of the interior of the preamp. Thanks John McIntosh
Here is a photograph of the inside of the Dynaco PAS-3 preamp without the tubes. I was afraid to install them with 500 volts showing. The two red wires are the 300 volt secondaries. The centertap to these is grounded to the chassis underneath and the two blue wires are what was represented as the 10.9 volt secondary.
The PC-5 board is the "line" board as opposed to PC-6 which is the phono board. PC-5 is powered by eyelets 16, 18 and 19. They all come from the Capacitor board and eyelet 16 is the high voltage and currently measures 500 volts. 18 & 19 are the low voltage lines. The schematic shows the bottom of a 4 capacitor "can" capacitor. Also a rectifier tube is shown. Both have been replaced by the updated solid state capacitor board which sits (pictured) next to the transformer. As far as tracing them back, there are only three wires: 16, 18 & 19. They go straight to the cap board. The other eyelets on this board are to tone and volume controls and a scratch filter switch.
  • PC-5 Schematic.pdf
What is the voltage rating of the capacitors on the Capacitor Board? This will give us a clue for the designed B+ voltage (high voltage).
From what I've been able to find on the Internet, about 470V without the tubes installed is normal. When the tubes are installed they will draw about 2 milliamps each thru a plate load resistor of 150K Ohms, this will drop the Plate voltage to around 150V. The B+ on eyelet 16 will go up and down a few volts as the line voltage varies. It will also drop when the tubes are in, probably by 20 to 40 Volts.
Let us know what you find.
Cheers,
Tom
ADDENDUM:
The specs look excellent regarding noise, distortion, pulse recovery, etc.
User Manual and Schematic are available for download at: https://www.hifiengine.com/manual_library/dynaco/pas-2.shtml
They require a valid e-mail address and what country you are in.
This information is extremely helpful! I bought this pre amp and sister power amp in 1972. I can't remember whether it was $50 each or $50 for the pair. They got me through college and beyond but were replaced . . . I recently started listening to them and just replaced the selector switch because I was losing the left channel. When I got the huge voltage I stopped and sought advice.
To answer your question I have uploaded the blurb from the replacement cap board. I elected to replace the rectifier tube (12X4) as suggested by Mr. Stokes, the designer of the board with a pair of diodes. The large capacitors are rated at 450 volts 47 mu F, the 1800 mu F are 25 volts. The orange things are 104K 630V. That seems to be .1 mu F film Capacitor rated for 630 volts.
You need to understand that at the time when something went wrong I took all the tubes down to the drugstore, hardware store or Radio Shack if there was one and replaced the ones that failed. No one ever told me how to measure the voltage at the tube pins. I just assumed that they would measure the same both ways.
I intend to wait until later tomorrow (Saturday) to test with the tubes installed. That would give time for any last minute emergency instructions.
Best
John
  • Cap Board Blurb.pdf
OK, good. That fits well with voltages estimated in my previous post. Unless someone comes up with a panic alert, it looks like you are good to go with tube replacement and enjoy the sound!
Tom
I had a similar experience with a guitar amp build recently and I can confirm that the voltage does drop to "normal" with the tubes installed and working. Can you post back and let us know how it went?
Thanks to everyone. With the tubes installed the voltage measurements were within specifications. I hooked up the unit and now it works fine.
John
Likes Tom.G
Related to Bench test AC transformer from stereo tube equipment
1. How do I bench test an AC transformer from stereo tube equipment?
To bench test an AC transformer from stereo tube equipment, you will need a multimeter and a power source. First, disconnect the transformer from the circuit and make sure it is not connected to any power source. Then, use the multimeter to test the resistance of the input and output terminals. If the resistance is too high or too low, the transformer may be faulty. You can also test the output voltage using the multimeter. If the voltage is significantly lower or higher than the rated voltage, the transformer may need to be replaced.
2. What does an AC transformer do in stereo tube equipment?
An AC transformer is responsible for converting the high-voltage AC power from the wall outlet into the appropriate voltage needed for the tubes in the stereo equipment. It also helps to isolate the circuit from the power source, preventing any potential electrical hazards.
3. How do I know if my AC transformer is damaged?
If your stereo tube equipment is not functioning properly, it could be a sign that the AC transformer is damaged. You can test the transformer using a multimeter as mentioned in the first question, or you can visually inspect it for any physical damage such as burns or cracks. If you are unsure, it is best to consult a professional for further diagnosis.
4. Can I repair a faulty AC transformer myself?
Repairing an AC transformer requires knowledge and experience in electrical engineering. It is not recommended for individuals without the proper training and equipment to attempt to repair a faulty transformer. It is safer and more effective to replace the transformer entirely.
5. How often should I bench test my AC transformer?
It is recommended to bench test your AC transformer at least once a year to ensure it is functioning properly. However, if you notice any issues with your stereo tube equipment, it is best to test the transformer immediately to identify and address any potential problems.
  • Electrical Engineering
