Bernoulli's equation explanation
In Bernoulli's equation, the work done on fluid at the lower end of a pipe is considered negative due to the established sign convention that defines upward movements and forces as positive, while downward movements and forces are negative. This convention is crucial for maintaining consistency throughout the derivation of the equation. Gravitational potential energy (GPE) is treated similarly, increasing as an object moves upward and decreasing as it moves downward, reflecting the negative work done by gravity. The potential energy term in Bernoulli's equation is based on this principle, calculated as density multiplied by gravitational acceleration and height. Adhering to this sign convention ensures that the results of the equation remain valid regardless of the chosen reference point.
shanewatson
In Bernoulli's equation, why the work on fluid at the lower end of the pipe is taken as negative?
please explain why the force is negative to displacement at the lower end?
Just a sign convention. Assume it the opposite : Lower end positive and upper end negative... The result will remain unchanged provided you keep on using the sign convention throughout the derivation.
The convention is to consider upwards movment and upwards forces as positive, and downwards movement and downwards forces as negative. Gravitational potential energy is the negative of the work done by gravity, so GPE increases (more positive or less negative) as an object moves upwards, and decreases as an object moves downwards. The potential term in Bernoulli's equation follows the same rule, but it's potential energy per unit volume (density x gravitational acceleration x height).
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
