How Does Bernoulli's Principle Apply to Varying Pipe Diameters and Water Flow?
Bernoulli's principle applies to a horizontal pipe with varying diameters, where gauge pressures of 34 kPa and 25 kPa are measured in the wider and narrower sections, respectively. To find the flow speed ratio between the narrow and wide sections, the relationship between flow rate and area is used, yielding a ratio of 2:5. The challenge arises in calculating actual flow speeds, as Bernoulli's equation involves two unknowns; substituting flow rates with Q/A simplifies the problem to one unknown. It's crucial to convert gauge pressures to absolute pressures by adding atmospheric pressure for accurate calculations. Understanding these principles will facilitate solving for the volume flow rate through the pipe.
Matt Armstrong
A horizontal length of pipe starts out with an inner diameter (not radius!) of 2.60 cm, but then has a tapered middle part which narrows to a diameter of 1.60 cm. When water flows through the pipe at a certain rate, the gauge pressure is 34 kPa in the first (wider) section and 25 kPa in the second (narrower) section.
(a) What is the ratio of the flow speed in the narrow section to the flow speed in the wider section?
(b) What are the actual water flow speeds in the wider section and in the narrower section? (Hint: you will need to set up and solve Bernoulli’s equation. Bernoulli’s equation determines what flow rate is produced by this particular pair of inlet and outlet pressures.)
(c) What is the volume flow rate through the pipe?[/B]
r_1 = .013 m, r_2 = .008 m, P_1 = 34000 Pa, P_2 = 25000 Pa
A = pi*r^2
Q=Av
P + .5rho*v^2 = constant
P_1 + .5rho*(v_1)^2 = P_2 + .5rho*(v_2)^2[/B]
For a, since the flow rate is Q = v*a, I made a ratio between the velocities and the Areas and got a ratio of 2 (for narrow) to 5 (for wider). Part b is where I have trouble. I know that Bernoulli's principle can be written between any singular point or any two points along the pipe, and I tried to solve for v_1 and v_2 using the second equation, but that wouldn't be possible because there are two unknown variables. I know that in certain applications where a difference in height delta-y can be used in a formula for velocity, but since no height or reference frame is identified, I left those out of my principle equations as well as neglected to use them. I feel like if I can understand part b, then I can do part c on my own. What do I need to do?
Thanks for any information you can provide
Hello,
You just need to substitute v1 and v2 with Q/A1 and Q/A2 respectively. Q (volume/time units) is the same because of the mass balance. So, the unknown variable will be one instead of two.
Beware: the problem gives you the gauge pressure, so you must add atmospheric pressure (101.325 kPa) in order to get absolute pressure and use it in the Bernoulli's equation.
Does it matter here, as long as the pressures are all from the same base?
You are right, it does not matter as long as pressure is added to each side of the equation and we solve for Q (ΔP remains the same).
But if we wanted to solve for P1 or P2, the result would have been wrong (in terms of units).
  • · Replies 16 ·
  • · Replies 30 ·
  • · Replies 61 ·
  • · Replies 17 ·
